We recently upgraded several devices to RouterOS 7.5 from 6.x. We had several APCUPS:es using USB connected.
Where is UPS, am I missing something ?
I can not find UPS settings, we no longer have our UPS:es monitored ad devices using RouterOS 7.5.
Thank you in advance!
I anser myself, it was in extra packages… how stupid
Anyhow, the APCUPS was not detected and beneath the system ups menu only serial port could be added, there is nothing in the logs. Maybe it only works with serial ports, that is nothing I to use. (Raspberry pi detected the apcups using the same cables.)
Looks like I could have made this posting …
I tried to get the USB port of my CCR1009 to regognize the APCUPS.
No luck, nothing on USB, not even the WOOBM stick from MT itself
Running 7.5, nothing in logs, nothing on USB
anyone got this working ?
I have exactly the same situation (CCD1009, CCR1016 and CRS125),
tried APCUPS first directly and via a small USB hub, no luck, tried WOOBM stick no luck. Nothing in logs.
Then I connected a flash disk to the USB port, and that was working it was detected cleanly, I formatted it and put a lot of files on it, all working and fast with little CPU consumed.
So I guess we have a situation here… RoS7.5 and USB devices like WOOBM and APCUPS.
