I am using DHCP(v4) to obtain IP addresses and default gateways.
In ROS 6 I could enable the “check-gateway” feature on DHCP provided routes using route filters with the “dynamic-in” chain.
This chain does not seem to “trigger” onto DHCP obtained routes in ROS7’s /routing/filter/rule system.
Is there any way I can match DHCP provided routes in /routing/filter/rule?
If not, is this planned? If yes, how would I match them?
