RouterOS access via VPN (IPsec)
Hi Everyone!
First of all, thanks for all the expert's time on this forum to make our life a LOT easier!
I have a small problem BUT it is still a problem...
I have the following setup:
Laptop/PC-----(Internet)-----SXT LTE-----Data Logger
The goal of this installation is to:
  • Provide internet for the remote data logger
  • Have secure remote access to the data logger
  • Have secure remote access to Mikrotik LTE
I used 'quick set' to program the LTE. Progress so far:
  • Internet for the data logger
  • The VPN working over the LTE connection (Default 'quick set' setup - IPsec)
  • I can ping the local IP of the mikrotik while connected via VPN
My challenge:
  1. I would like to use Winbox to access the mikrotik, but Winbox does not see the mikrotik if connected with the VPN
  • Not sure if this is possible or best practice, I guess I can do port forwarding for the Winbox. But it feels 'safer' to only open VPN to the outside world
  1. As backup; I cannot access the webfig of the mikrotik even though I can ping the local IP via the VPN
  • If I disable the 'drop all WAN' firewall filter, then I can access the webfig. Maybe I am missing a firewall filter?
Any advise will be appreciated!!! Also on possible improvements on my firewall.
Below is the export
(I removed some detail)
Export:
oct/03/2017 19:22:42 by RouterOS 6.40.3
software id = ......
model = RouterBOARD SXT LTE 3-7
serial number = .........
/interface lte
set [ find ] add-default-route=yes apn=unrestricted default-route-distance=1 mac-address=....... name=lte1 network-mode=lte use-peer-dns=yes
/ip neighbor discovery
set lte1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.90.10-192.168.90.254
add name=vpn ranges=..........
add address-pool=dhcp disabled=no interface=ether1 name=defconf
/ppp profile
set *FFFFFFFE local-address=........... remote-address=vpn
/interface l2tp-server server
set enabled=yes ipsec-secret=..... use-ipsec=yes
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.90.1/24 comment=defconf interface=ether1 network=192.168.90.0
/ip cloud
set ddns-enabled=yes
add address=192.168.90.0/24 comment=defconf gateway=192.168.90.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat out-interface=lte1
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=........0/24
/ppp secret
add name=..... password=.....
/system clock
set time-zone-name=Africa/Johannesburg
/tool mac-server
add interface=ether1
/tool mac-server mac-winbox
For management over the VPN you need to add a firewall filter rule. Like this, where 192.168.1.0/24 is the LAN I am connecting FROM.
chain=input action=accept protocol=tcp src-address=192.168.1.0/24 dst-port=80,443,8291 log=no log-prefix=""
