TL;DR RouterOS is always sending traffic for 81.0.0.208* out of the sfp-sfpplus1 interface, back to our upstream provider. It has a valid route for routing this address internally. Assigning this IP to a local interface has no effect.
Details:
I run a small ISP and this issue relates to our edge router. The edge route has BGP peering to our upstream provider. The subnet used for this is 81.0.0.94/30*. We also advertise the prefix 81.0.0.208/29*, which they then route to us. These IPs are used as follows:
- 81.0.0.208-209 - Routed internally, each as a /32
- 81.0.0.210-215 - CGNAT on the edge router, each IP attached to sfp-sfpplus1 as a /32
Previously, these IPs were attached to sfp-sfpplus1 using a /29 prefix (i.e. 81.0.0.208/29), which was a mistake. I’ve changed this to a /32 as I now want to route .208 & .209 internally.
The CGNAT works fine, and 81.0.0.209 is routed just fine. However, RouterOS always sends traffic to 81.0.0.208 out of the sfp-sfpplus1 interface (to the broadcast MAC address). That made sense when I was using 81.0.0.208**/29** as a subnet attached to sfp-sfpplus1, but that is no longer the case. Yet RouterOS is still behaving as though 81.0.0.208 is a broadcast address on that interface.
I have even assigned this IP to a local interface, which had no affect at all. I also created a manual ARP entry, which was completely ignored.
It is quite possible I am doing/thinking something silly here, but I have looked into this for several hours now. I’ve done a /export and checked for references to 81.0.0.208, but nothing seems out of place.
The only thought I have now is, “perhaps its internal state has got messed up”. So I’m considering doing a restart of the router, but that’ll take down our ISP for a few (nail-biting) minutes. Is my “turn it off and on again” solution a good one, or are there any other better options?
Router is an RB4011 running 6.47.10.
Any advice would be welcome.
*Not the actual IP
hello @ adam,
well, maybe you could give us a little bit of clue about your interface and ip configuration - which you think problematic . otherwise we would have no idea?
maybe along with bgp peering config?
and please… not the whole export - my eyes hurt
Hi @wiseroute. Sure thing, and thank you. I think this is everything relevant:
set [ find default-name=sfp-sfpplus1 ] name=sfp-sfpplus1-iptelecom
/interface vlan
add interface=sfp-sfpplus1-iptelecom name=core-transit-iptelecom-1 vlan-id=230
add interface=ether1 name=core-vlan vlan-id=100
add interface=ether1 name=management vlan-id=84
add address=10.100.0.2/16 interface=management network=10.100.0.0
add address=100.127.0.2 interface=loopback network=100.127.0.2
add address=81.0.0.94/30 interface=sfp-sfpplus1-iptelecom network=81.0.0.92
add address=81.0.0.210 interface=sfp-sfpplus1-iptelecom network=81.0.0.210
add address=81.0.0.211 interface=sfp-sfpplus1-iptelecom network=81.0.0.211
add address=81.0.0.212 interface=sfp-sfpplus1-iptelecom network=81.0.0.212
add address=81.0.0.213 interface=sfp-sfpplus1-iptelecom network=81.0.0.213
add address=81.0.0.214 interface=sfp-sfpplus1-iptelecom network=81.0.0.214
add address=81.0.0.215 interface=sfp-sfpplus1-iptelecom network=81.0.0.215
add address=100.125.0.2/24 interface=core-vlan network=100.125.0.0
/routing bgp instance
set default as=65000 client-to-client-reflection=no comment="[ ID:main ]" redistribute-other-bgp=yes redistribute-static=yes router-id=100.127.0.2
/routing bgp network
add network=81.0.0.208/29 synchronize=no
add network=81.0.0.210/32
add network=81.0.0.211/32
add network=81.0.0.212/32
add network=81.0.0.213/32
add network=81.0.0.214/32
add network=81.0.0.215/32
/routing bgp peer
add default-originate=if-installed hold-time=1m30s multihop=yes name=core out-filter=internal-out remote-address=100.127.0.1 remote-as=65000 update-source=loopback
add in-filter=iptelecom-in name=iptelecom-v4 out-filter=iptelecom-out remote-address=81.0.0.93 remote-as=29003 tcp-md5-key=IPT-GDN
add address-families=ipv6 in-filter=iptelecom-in name=iptelecom-v6 out-filter=iptelecom-out remote-address=2a02:8f0:a1ff:d2da::1 remote-as=29003 tcp-md5-key=redacted
# Relevant routes:
0 ADb dst-address=0.0.0.0/0 gateway=81.0.0.93 gateway-status=81.0.0.93 reachable via sfp-sfpplus1-iptelecom distance=20 scope=40 target-scope=10 bgp-as-path="29003"
bgp-origin=incomplete received-from=iptelecom-v4
11 ADb dst-address=81.90.51.208/32 gateway=100.127.2.1 gateway-status=100.127.2.1 recursive via 100.125.0.1 core-vlan distance=200 scope=40 target-scope=30 bgp-local-pref=100
bgp-origin=igp received-from=core
30 ADo dst-address=100.127.2.1/32 gateway=100.125.0.1 gateway-status=100.125.0.1 reachable via core-vlan distance=110 scope=20 target-scope=10 ospf-metric=45 ospf-type=inter-area
hello @ adam,
did you mean: inbound from internet to your network? or outbound from local to internet?
btw, do you have any loopback interface with ip addresses inside your router?
i am sorry, my mistake. i didn’t mean to export the config but :
- ip address print details
- interface print details
- ip route print details
- and, nevermind for that bgp .
No problem:
To rephrase for clarity: However, RouterOS always sends traffic to 81.0.0.208 out
of the sfp-sfpplus1 interface, headed out of our network, towards our
upstream provider (to the broadcast MAC address).
Yes. 100.127.0.2, see below
[admin@edge] /ip address> pr
# ADDRESS NETWORK INTERFACE
0 10.100.0.2/16 10.100.0.0 management
1 100.127.0.2/32 100.127.0.2 loopback
2 81.0.0.94/30 81.0.0.92 sfp-sfpplus1-iptelecom
3 81.0.0.210/32 81.0.0.210 sfp-sfpplus1-iptelecom
4 81.0.0.211/32 81.0.0.211 sfp-sfpplus1-iptelecom
5 81.0.0.212/32 81.0.0.212 sfp-sfpplus1-iptelecom
6 81.0.0.213/32 81.0.0.213 sfp-sfpplus1-iptelecom
7 81.0.0.214/32 81.0.0.214 sfp-sfpplus1-iptelecom
8 81.0.0.215/32 81.0.0.215 sfp-sfpplus1-iptelecom
9 100.125.0.2/24 100.125.0.0 core-vlan
10 D 10.111.0.1/32 10.111.0.10 <ovpn>
[admin@edge] /interface> pr
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R ether1 ether 1500 1592 9578 48:8F:5A:99:B8:42
1 ether2 ether 1500 1592 9578 48:8F:5A:99:B8:43
2 ether3 ether 1500 1592 9578 48:8F:5A:99:B8:44
3 ether4 ether 1500 1592 9578 48:8F:5A:99:B8:45
4 ether5 ether 1500 1592 9578 48:8F:5A:99:B8:46
5 ether6 ether 1500 1592 9578 48:8F:5A:99:B8:47
6 ether7 ether 1500 1592 9578 48:8F:5A:99:B8:48
7 ether8 ether 1500 1592 9578 48:8F:5A:99:B8:49
8 ether9 ether 1500 1592 9578 48:8F:5A:99:B8:4A
9 ether10 ether 1500 1592 9578 48:8F:5A:99:B8:4B
10 R sfp-sfpplus1-iptelecom ether 1500 1600 9586 48:8F:5A:99:B8:4C
11 DR <ovpn> ovpn-in 1500
12 R core-transit-iptelecom-1 vlan 1500 1596 48:8F:5A:99:B8:4C
13 R core-vlan vlan 1500 1588 48:8F:5A:99:B8:42
14 R loopback bridge 1500 65535 46:2D:85:E0:5F:01
15 R management vlan 1500 1588 48:8F:5A:99:B8:42
[admin@edge] /ip route> pr
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 ADb 0.0.0.0/0 81.0.0.93 20
1 X S ;;; Enable if BGP peering goes down
0.0.0.0/0 81.0.0.93 1
2 A S 10.32.0.0/12 10.111.0.10 1
3 ADC 10.100.0.0/16 10.100.0.2 management 0
4 Do 10.100.0.0/16 100.125.0.1 110
5 ADo 10.110.1.0/24 100.125.0.1 110
6 ADC 10.111.0.10/32 10.111.0.1 <ovpn> 0
7 A S 10.200.0.0/16 10.111.0.10 1
8 A S 10.200.0.10/32 10.111.0.10 1
9 A S 10.200.0.11/32 10.111.0.10 1
10 ADC 81.0.0.92/30 81.0.0.94 sfp-sfpplus1-ip... 0
11 ADb 81.0.0.208/32 100.127.2.1 200
12 ADb 81.0.0.209/32 100.127.2.1 200
13 ADC 81.0.0.210/32 81.0.0.210 sfp-sfpplus1-ip... 0
14 ADC 81.0.0.211/32 81.0.0.211 sfp-sfpplus1-ip... 0
15 ADC 81.0.0.212/32 81.0.0.212 sfp-sfpplus1-ip... 0
16 ADC 81.0.0.213/32 81.0.0.213 sfp-sfpplus1-ip... 0
17 ADC 81.0.0.214/32 81.0.0.214 sfp-sfpplus1-ip... 0
18 ADC 81.0.0.215/32 81.0.0.215 sfp-sfpplus1-ip... 0
19 ADb 81.0.0.216/32 100.127.2.1 200
20 ADb 100.65.1.0/24 100.127.1.1 200
21 ADo 100.65.2.0/26 100.125.0.1 110
22 ADC 100.125.0.0/24 100.125.0.2 core-vlan 0
23 ADo 100.126.0.0/29 100.125.0.1 110
24 ADo 100.126.0.8/29 100.125.0.1 110
25 ADo 100.126.0.16/29 100.125.0.1 110
26 ADo 100.126.0.24/29 100.125.0.1 110
27 ADo 100.127.0.1/32 100.125.0.1 110
28 ADC 100.127.0.2/32 100.127.0.2 loopback 0
29 ADo 100.127.1.1/32 100.125.0.1 110
30 ADo 100.127.2.1/32 100.125.0.1 110
I bit the bullet and did a restart. It fixed the issue immediately.
I would love to know how I could have resolved this without doing a restart though. Can I clear out the router’s caches manually somehow?
