Hi any body has installed RouterOS on ALix Board before and Can help ??
i want the steps to do it .. and thanks
Sure… which Alix model? Guess you’ll be using a CF card; download netinstall from mikrotik, download the RouterOS version you want to install, plug the CF card in that PC, then use netinstall to install that version to the CF drive letter.
If everything goes well plug this CF to the Alix board, and you’re done.
the model
in the netinstaller i have choose select all (but not working) and also installing routerosx86 and i get the same problem
Missig operating system
Are you sure you netinstalled to the right drive letter?? Try setting the Alix to CHS mode.
If that doesn’t make a difference, try a different CF card.
Cannot see any Alix model number there. Look at the PCB board, it should be silkscreened somewhere.
The Model is 2D2
Have that model next to me with ROS… verify you netinstalled to the proper drive letter. Set it to CHS. If that doesn’t help Try a different CF.
Still not working if you can make a tutoriel how you have do it i will appreciate ![]()
try to make CF card with 6.26 netinstall and routeros
and then upgrade to 6.28
That Works Thanks a Lot
but where i can buy a licence ?? and wich licence is the best for having VPN ??
Hello, I have to install ROS on a CF card for the same board ALIX 2D2. I tried with netinstall , with versions 7.2, 6.48.6 and 6.49.5 but the same behaviour happens during boot, it shows Loading system with initrd and never reach the login screen. The yellow LEDs of the two ethernet ports are on, with no cables in them.
I also tried to install from ISO from a virtual machine with VMWare, inside VMware the OS boots find, but not inside the board.
I would like to try this solution of using v6.26 (mentioned on http://forum.mikrotik.com/t/routeros-and-alix-2d2/86878/1 as well) but I cannot find this version.
Any other solution to work around this problem?
Thanks for your help
If it can help, I resolved the issue at my side which was due to the different default speed setting for the serial port.
On ALIX 2, the default speed is 38400.
On RouterOS x86, it is 9600.
It was just a matter of setting my TTY client to the correct speed and wait 1 - 2 mins before the login prompt would show up.
Stop resurrecting old topic
