Is it possible to have RouterOs + Radius Manager + Squid Proxy on Single Machine.
RouterOs
(PPPoE Server + Firewall + Bandwidth Manager
Radius Manager
(Mysql+FreeRadius+FrontEnd+Squid proxy)
All on same machine. if someone tried it.
Atif Khan
RouterOs
Radius Manager
Atif Khan
Yes its possible. All the machines i have are way overbuilt. I don’t have any issues.
Matt
can you please explain in details how can you achieve this.
Many thanks
I would like to know how you did it. how its possible. what hardware did you used what os did you used. kindly provide more information to understand it better.
Atif Khan
You can do this by using VMware. Just to be careful, pay really close attention on the amount of processor power and ram you have.
Matt
Can you please be more specific:
Many thanks
What is the mane OS ? Is it Windows ?
Fedora and MT
What is the VMware you use ? Is it Microsoft VM
VMware
What is your recommendation for CPU and RAM ?
I would recommend a dual core processor in the manor (2GHz+). The dual core process will help with VMware and fedora, but secondary core will not be utilized in MT.
2GB+ RAM
Did you use this machine in real environment ?
Yes (also tested with gaming users)
What is the amount of your traffic ?
5MB-10MB/2MB-7MB of Traffic per second
What is the number of your concurrent users ?
~400
Never Tired VMware but i would love to try it. I need some starting point to start using VMware any good tutorial site for startup of VMware.
And define little info about steps for
Installation RouterOs + fedora Core 5
You will need to run two virtual machines. One with RouterOS and One with Fedora Core. This can all be done a single machine.
If you search online search for preloaded Fedora core appliances. The are free and save you the time configuring it and setting it up. You can download a preloaded VMware appliance with Squid preloaded from http://www.vmware.com/vmtn/appliances/directory/57
Then after you got that running create another additional virtual machine and load it use pxe if possible and then use netinstall to install it onto the virtual machine.
Hopefully this helps some.
Matt
If you have 8 ether ports in the machine, you can assign each to which ever partition/VM that you wish? Can you assign CPU affinity, etc also?
Well you can assign nics to the VM machine you want. When it comes to the CPU affinity you are going to set that in windows on the VM software.
