RouterOS and Tx Power regulation.
does anyone tried if the regulation in RouterOS on RBxxx really work with R52 or CM9 cards ???
If I set in Wireless / TX power / manual option and I will set 5dBm (or something else from -10 to 17dBm) then if I have really 5dBm output on TX (or from -10 to 17dBm) ?
I have no measure instruments to try it. And by adjusting it on point to point connection to find, if the regulation work is unable. The recieve signal strength is hooping ± 2dB.
I have heard, that someone tested it on some meeting and it not work by step 1dBm.
EXAMPLE:
TX POWER set: MEASURED TX power:
10 10
9 10
8 11
7 7
and so on
we have measured the tx-power and it is working fine.
OK,
Thanks for reply…
