Does RouterOs works as DNS Server??
I dont want have linux here anymore !!!
But DNS server is need …
it will act as a DNS cache http://www.mikrotik.com/docs/ros/2.9/ip/dnscache
You can also enter static A records.
It all depends on what you need DNS to do.
Regards
Andrew
mikrotik dns’s is dns client and name caching only.
NO A,CNAME,NS records will spread to the world, If I’m correct! ![]()
/ip dns static allows you to add static A records. This is rather more than just name caching.
Regards
Andrew
Yeah, well, it’s more like adding static entries to the cache. RouterOS does not implement enough of DNS to allow it to be an authorative server for a zone. It can only act as a (caching) resolver. But that’s enough in my book, a router is a router and a DNS server is something else.
–Tom
Agreed. I use the static A records to point to a few internal boxes, nothing more.
Regards
Andrew
well if you want to use easy dns management, just try free dns service laying on the internet, like zoneedit, freedns, etc. ![]()
