RouterOS basic DHCP question
I run a RB3011 router router with RouterOS 6.38.
Looks to be running fine although the POE looks to be broken.
Where can I find the DHCP IP-tables where I can see which address is given to each device?
Where can I set a fixed or preferred address for some devices?
Please help, I am a bit overwhelmed with all options I see.
I know the feeling…
In Winbox
IP → DHCP Server → Leases
you can see all the DHCP leases, doubleclick and you can make them static and also changed the IP if you like.
//A
The Beginner Basics forum is more suitable for this question. Perhaps a mod can move it.
Sorry I’m unable to help with PoE.
You can see this in /ip dhcp-server lease
Also in /ip dhcp-server lease. Right click on a device and select “Make Static”. After that you can change the IP address for that device.
Thanks for helping.
It looks like not all devices are listed though. I have a Qnap NAS and a Unraid server, which are available on the network but I don’t see them in the list.
Can you tell me why?
Perhaps they have static addresses set manually and not DHCP?
