I am trying to add a BGP filter to set a local preference to a specific AS.
Initially I just used prefix filters and it has worked fine, however for some bigger networks it seems wiser to filter via an AS, less typing, less updating.
prefix filter:
chain=ibgp-mt1-out prefix=66.102.0.0/20 invert-match=no prefix-length=20-32
action=passthrough set-bgp-local-pref=200 set-bgp-prepend-path=""
So instead of using prefix filters like above, I have made a new one for an AS like this:
as-path filter:
chain=ibgp-mt1-out bgp-as-path=",15619\$" invert-match=no
I have verified that the regexp is correct by typing:
/ip route print detail where bgp-as-path ~ ",15619\$"
which returns routes whose destination is AS15619.
However, unlike the prefix filter, which takes at most a couple of minutes or so to update the routing table with the local preference I set, the as-path filter seems to have no effect at all. I don’t see any updates in the routing table eventhough a lot of time has elapsed and to me everything seems to be setup correctly.
I am wondering if anyone has been successful with an as-path bgp filter for RouterOS as I unfortunately cannot find many examples online.
Thank you.
