RouterOS Boot Failure
My RouterOS wont boot after a power failure. When I connect a monitor to it all I see on the screen is…
LILIO 22.3.4 Loading System…
BIOS data check successful
Uncompressing Linux…Ok, booting the kernel
Starting…
And it ends there for hours.
try to move the hard drive to another computer and see if it works there. make sure you have the same BIOS settings, and that you connect the drive in the same way as in the current computer (if it is Primary Master, LBA mode in the first computer, it must be the same in the other computer). if still nothing, you may need to reinstall the software
Men thanks! It worked like magic but… what really happened or caused it?
Have a yummy day! :smiley:
