May I join this discussion as to why? From the very beginning, and even now, the bridge, bridge port is confusing. It will always be confusing because it is an insufficient abstraction for the people who use it. This is why @sindy can not make it any clearer. No one more capable and patient than him could be hired to do so, and yet, it is as murky as would be dark waters in the south pacific rim from falling volcanic ash.
Abstraction
Abstractions are very important in the software industry. Generally speaking, programmers create them (implemented from specifications created by software architects which maybe the same person). Then technical writers try to explain them. Marketers then try to sell them. If the abstractions are too close to the hardware, another layer of abstraction is created to make it more sensible, easier to reason about. In programming code, these abstractions are another class (object) that manages the inputs and outputs of the lower (closer to hardware) object. There maybe several. There maybe ten before anyone outside the company sees the final layer.
These layers mean something to different groups based on their needs and use cases. Consider the following: an ethernet frame gets assembled from a nic driver on a PC. A switch, reading in the series of electrical or optical impulses stores the bits in a buffer, a software object identifies the object as a frame, another object responsible for modifying frames inserts a VLAN tag, and so on. This abstraction is well below the needs of people who write programs for your computer. This abstraction is unnecessary and a distraction for them. So, another layer they use allows them to read into a memory buffer, and output file or screen data in a loop. They don’t need such verbose access to the wire.
How all these physical things get abstracted by programmers is something that may never be exposed to the network admin. In fact, a final abstraction, often termed the API, is what most generally gets exposed to customers and end uers. And that abstraction is what is the most important thing to MikroTik product administrators, forum commenters, explainers, and apologists. You and me. We care about the RouterOS API (syntax and Winbox).
The Missing Abstraction:
While at first I was thinking it was RouterOS’s fault, and indeed it could be a missed opportunity, the real issue, the real blame, the real source of confusion is the missing abstraction that we don’t have. Point your fingers at what does not yet exist! Therein lies the blame. Do not blame what we have, blame what we lack.
RouterOS, I theorize, is closely tied to Linux. It is a layer upon Linux and this layer is itself tied to the RouterOS syntax and how that relates to Winbox. Did you catch that? That is a line of dependencies. RouterOS, I suspect, is not an abstraction over a multi-vendor routing, switching, VLAN, whatever concept. Instead, it is a layer over Linux. This layer is tied to the way their GUI (Winbox) works which tries to be like RouterOS text syntax, which in turn tries to simplify the underlying Linux commands.
MikroTik could have created a syntax and GUI in isolation. However, they may not have separation of concerns in-house. The code is too intertwined. A point could be made that MikroTik should have started with an API concept, then separately picked a syntax, and then a vendor (Linux), to make the switching concept physically become a reality. But that is unfair. They’ve made a great product and we love it. As with all things, there is always something to improve. Looking back one can see more clearly. Maybe they should consider a new end user API. Start with the API, and work backwards from there, in fact. That would clear up all this confusion. But that is a business case for them and not for us to decide.
Conclusion:
So, step away from the MikroTik documentation, my own comments, and all the writing about MikroTik’s implementation for a moment. What is a switch and a router doing, conceptually speaking, when operating under the VLAN standard? When you have that diagrammed, demonstrated, understood, and explained, then you can show others how RouterOS API chose to implement this.
But here’s the deal. You may never be able to explain, however, why RouterOS does it this way. The RouterOS abstraction maybe based on a model that is not reflective of where their customer’s operate. It may not be where you and I actually live. What if RouterOS, the one that we know, is actually for programmers and not network admins? You and I fellow forum co-patriots, we are the ones who are assembling networks. RouterOS may have not been for us. It may have been for the programmers that designed it. They understood it. It made sense to them.
We have become the missing abstraction. We make RouterOS work with network concepts. This means the bridge port, lacking MikroTik’s explanation, is whatever @sindy says it is.
