RouterOS CDC support
I am having some trouble with a CDC device: http://www.clear.com/devices/details/id/devatlas “‡ Linux, Android and Chrome require Remote Network Driver Interface Specification (RNDIS) or Communication Device Class (CDC) support”
The device shows up in the system resources USB section:
Vendor: Beceem Communications
Vendor ID: 0x198f
Device ID: 0x8160
The trick is its just straight up EoUSB no users or passwords just bind a DHCP client and your on your way.
Thanks,
Don
Edit: I forgot to include that I started with ROS 6.0.rc3 then downgraded to 5.21 on a x86 system
