RouterOS Changes
Does anyone know what the -SP means in the Wireless Registration table in 3.0? As an example, it shows Tx/Rx Rate as 11Mbps-SP/11Mbps-SP
Short Preamble
-Gerard
usually windows clients will force routeros to use B not G while using wireless connection
to force windows clients to use G mode, then AP to mode=g-only
That’s funny… I have an old-school vivato 802.11b only panel that is constantly getting bumped by a routerboard with far lower signal quality but is running in 802.11b/g mode. It’s difficult getting windows to spit out exact rx/tx signal quality and speed info, but I suspect that the routerboard is association “speed” is higher (despite the extra distance) than the 802.11b vivato panel can manage.
