I’m new to the routeros command line, but I find it much more pleasant to use than winbox/webfig, except for a few issues:
How do I add a line between some existing lines?
For example: I have a jumplist with firewall rules and the last two lines are log and drop and I want to add a line before them. Now I add the line via ssh and then log into webfig where I reorder the lines. -
How to operate on specific print results?
I do /ip firewall filter print chain=input and see the results. There are 11 rules in the input chain and I want to remove line #4. If I do remove 4 it will remove the #4 from the list of all the chains.
