Hello, I need help getting the default configuration. I did complete a full format/reset using NetInstall that finished successfully last night. I also did Reset Configuration from WinBox GUI today.
I changed my mind and decide I want to start from the Default Configuration. Where I get 192.168.88.1 IP already setup, and maybe a basic firewall configuration.
Push and hold reset button for, generally, ~7 seconds while plugging it in (i.e. until, generally, USR light blinks). That will get you back to the default configuration stored.
See https://help.mikrotik.com/docs/display/ROS/Reset+Button
One note: If you replace the default with netinstall, well, then, you do need to use netinstall to replace default again.
I’ve tried obtaining text file from link below, and copy paste to script in WinBox. Reboot Mikrotik router, but still IP address is 0.0.0.0, quickset is blank.
Keep in mind… not all router have a default configuration, or 192.168.88.1 exists only on one port without DHCP. Only the home/CPE-like routers have the default firewall.
Hmm. I hadn’t noticed they had the config now in the docs. For those, you’d need netinstall to replace the default configuration… but still how well it work still depend somewhat on the router.
Thanks! Your first suggestion worked, for a moment. But, after I move mikrotik router to WAN and plug 2 ethernet cables into mikrotik. one desktop and one to internet coming into house, the router no longer has that IP already setup. 192.168.88.1 is gone. But it was there when I was directly plugged from desktop win11 to mikrotik router with one ethernet cable.
Is WinBox supposed to keep showing me the MAC address device and a 2nd item in the WinBox list, 0.0.0.0?
all Youtube videos, only show one item in WinBox list, when first opening WinBox to connect to something.
