RouterOS default configuration
I got the PHP API working yesterday after changing
4   ;;; default configuration
     chain=input action=drop in-interface=ether1-gateway
to
     chain=input action=accept in-interface=ether1-gateway
I was hoping I could load configuration files into the router with the API without having to change the firewall filter options.
After changing the that firewall rule I was finally able to connect with API port 8728. Is there a way around this, DHCP maybe?
You really need to add a rule that specifically allows your API server to talk to the MT, not the whole world.
Place this before the default configuration of the firewall.
add chain=input action=accept in-interface=ether1-gateway src-address=“YOUR_API_SERVER_IP”
Oh sure, I will do that then. Ideally I was looking for a way to configure the router with just the use of the dhcp client on ether1 and the API server without going into the CLI.
But I guess there is no other way to communicate with the API server then to add a firewall filter rule.
if you are connecting to ether1-gateway - no there is no other way, there is no way on how to connect to presumably external interface. Also, while examples here and examples on wiki are for CLI, same applies to winbox or webfig.
Also, if router comes in new, usually it is set up to boot with flashfig enabled. That might help you a bit.
Hmm, this could be something I can use. I see that you need a windows computer with Netinstall/Flashfig installed. I don’t use anything that is windows based.
My current setup is that I have a linux server that will be on the same broadcast domain as the CPE. The CPE gets an IP-address from a DHCP server (there is a DHCP-relay in between) on the standard dhcp-client interface (ether1-gateway).
The linux server has configuration files stored for RouterOS clients. Is there a way I can make flashfig work with this setup? Or do I need to prepare the CPE before placing it at a customer’s premises?
you can use wine to run netinstall tool.
I can use wine on the Linux server (ubuntu server 12.04 LTS)?
netinstall will require GUI to configure it. Temporary KVM guest linux running wine could solve the issue.
janisk, thanks a lot for replying to my posts. This will help me a lot in my project :slight_smile:
