routeros does has more function with ?
As you know, the Cisco ios, if you press “?”, It displays a prompt to you, routeos also have this feature.
However, in ios, if the content is displayed more than one screen, it just shows the front of the contents, press spacebar to continue through the back of the display, seemingly without this feature routeros, and I do not know correctly?
linux has the “more” function.
can’t you scroll up with your mouse, or keyboard?
you can also hit [tab][tab] to show available options
First, thank you
I tried, the mouse can not scroll, tab is possible,
But from tab, it can not see the comment command
