RouterOS + Dude Web Interface problems...
I set up Dude 3.1 on RouterOS 3.19 and I am getting problems accessing the web interface. It is set by default on port 81 and is unchangeable. On 3.0 we didn’t have the problems with the web interface.
The problem that is being experienced is when we try to log in to the web interface it locks once the username and password are entered. It just sits and never does anything. I have tried this with a backup loaded and without. I thought maybe it was a bug with loading a backup from an x86/Windows Dude since it would have port 80 as the default port, but even with no configuration I still get the same problem.
Is anybody else having this same problem?
I’ve the same problem with ROS 3.18, 3.19 and dude 3.1. I have x86 based platform.
The same on 3.17 - 3.18. Platform x86
I just thought I would bump this and see if we could get an acknowledgment from the Mikrotik guys directly.
I have tried the Dude 3.1 package on both x86 (what I started this post with) and mipsbe and both have the same results.
You mean like this? I just clicked on web access, changed the port to 81, and then clicked on Enabled. It works right away. Or am I missing something?
The difference lies in the fact that our dudes are running on the ROS. Your dude is PC based standalone aplication - in this case I don’t have a problem.
As you can see, web access is enabled. In the next step, I try to login. After entering the username and password, and press a ‘Connect’ key, the connection with web server is broken. Since then, the server is no longer available and did not respond.
I tried to disable/enable web access, but the only option is to reboot the ROS.
his problem is by remote server.
localhost … You are running dude on windows - and this works fine (windows don’t work fine anyway… )
When You set www access on dude @ mt (I did tests on 3.17 and 3.18) then will don’t work.
yes, sorry - didn’t notice. It seems you are right and Dude on RouterOS webserver doesn’t work. We will look into this
Running 3.19 on x86 with Dude 3.1
I can enable it though I am forced to port 81.
Using IE I can go to the login page but upon login in crashes Dude
Then after Dude came back disabling and re-enabling the web interface doesn’t work at all. I can’t even telnet to 81.
i’m using RouterOS 3.20. dude-3-1.npk installed ok and can navigate do http://(mikrotikip)/dude but freezes at login
anyone getting any closer to the solution ?
Yes, I’m seeing this too.
Nick.
I have the same problem, any advance with the solution?..
regards
i have the same problem, but we have to wait to the next release. Normis say that they know this issue.
M.
Any progress on 3.2 over there?
I have the same problem with ROS 5.8 and dude 4.0 beta 3 :frowning:
add 5.9 + 4 beta 3 to the list, can enable service, can’t change port, and all attempt to load get no responce from server
As far as I can see from this thread this is an ongoing issue for at least 2 years now, can we get some sort of progress update
I have the same problem with ROS 5.8 and dude 3.6
Is there any solution for this yet?
ROS 5.6 with dude 3.6 - web server still doesnt work :frowning:
ROS 5.7 x86 + Dude 4.0beta3 - web server still doesnt work :frowning:
Tried also on CentoOS 6 with’out X, web ui does’nt work.
Ports for Dude connection 2210 and 2211 are fine.
