We often experience mysterious ethernet lock-ups and unexplained slowness. On Canopy and whatnot we get a lot of ethernet stats. Would it be possible to get the basic stats on ethernets like we get on a typical Linux box? Here is an example:
RX packets:46153205 errors:0 dropped:0 overruns:0 frame:0
TX packets:21638167 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:100
RX bytes:586744856 (559.5 MiB) TX bytes:3750889879 (3.4 GiB)
Please forgive me if I am asking for something in 4.X we are stabilizing on 3.30 right now.
-jim wiegand
vistavox
savage
January 20, 2010, 8:40am
2
It’s supported.
3.x you can get it via SNMP, 4.x allows it to be fetched via SNMP, as well as in winbox / console.
wow… seems like there are many parameters, but none of them is working…
[admin@MikroTik] > :put [/interface ethernet get srv rx-<TAB> ]
rx-1024-1518 rx-512-1023 rx-broadcast rx-multicast rx-too-long
rx-128-255 rx-64 rx-bytes rx-overflow
rx-1519-max rx-65-127 rx-fcs-error rx-pause
rx-256-511 rx-align-error rx-fragment rx-runt
any value prints empty string. checked with v3.28 and v4.1
Yeah the SNMP works for me. I checked the counters in an RB750 against WaveRider CCU counters and saw similar numbers. That gives me more to go on until we upgrade.
Thanks,
-jim
normis
January 25, 2010, 1:56pm
5
actually, on some devices we have this command:
[admin@MikroTik] > interface ethernet print stats detail
name: ether1-gateway ether2-local-master ether3-local-sl>
rx-broadcast: 941248 492 0 >
rx-pause: 0 0 0 >
rx-multicast: 644959 2410 0 >
rx-fcs-error: 0 0 0 >
rx-align-error: 0 0 0 >
rx-runt: 0 0 0 >
rx-fragment: 0 0 0 >
rx-64: 986414 555864 0 >
rx-65-127: 628783 60702 0 >
rx-128-255: 231746 201841 0 >
rx-256-511: 46113 27298 0 >
rx-512-1023: 27302 25702 0 >
rx-1024-1518: 999700 62813 0 >
rx-1519-max: 0 0 0 >
rx-too-long: 0 0 0 >
rx-overflow: 0 0 0 >
rx-bytes: 1684455329 204962284 0 >
tx-broadcast: 1352 5926 0 >
tx-pause: 0 0 0 >
tx-multicast: 0 5926 0 >
tx-underrun: 0 0 0 >
tx-64: 524178 114507 0 >
tx-65-127: 83028 70431 0 >
tx-128-255: 182308 189942 0 >
tx-256-511: 28455 30448 0 >
tx-512-1023: 25695 24554 0 >
tx-1024-1518: 62377 939921 0 >
tx-1519-max: 0 0 0 >
tx-too-long: 0 0 0 >
tx-collision: 0 0 0 >
-- [Q quit|D dump|right|down]
Normis, what devices offer such detailed iterface info? On RB433 I get nothing…
aldis
January 31, 2010, 1:15pm
9
works on RB450G, v3.30, as well
RB600 with v4.5
[admin@R1] > /interface ethernet print stats detail
name: ether1 ether2 ether3
[admin@R1] >
e.g. it no longer works
normis
February 4, 2010, 7:09am
11
no, it does work. only on the routerboards that use the same chip as RB450 and 750. not all chips give such info.
