RouterOS Feature request: NTP client Time
hi,
on the NTP client config page one can set/change parameters and you can see Stratum and if it is synchronized or not, even whats the time difference to system time.
But what you cannot see on this page is the time itself! Which is in my opinion the most important thing and probably the reason why one is on this page. So it would be great if the current system time and time-zone would be listed there as well on separate lines …
hope that makes sense to others as well
regards
itchako
Time and date are available in:
/system/clock/
