RouterOS Firewall configuration when using a bridge with multiple VLANs
I’m attempting to migrate my existing router configuration from using multiple bridges (one per VLAN), to a single bridge, as described in https://help.mikrotik.com/docs/display/ROS/Bridge+VLAN+Table.
While this is working well for our switches, I am running into issues when attempting to do it on our router.
Should I be using this single bridge configuration option on our routers as well as our switches?
The core issue is related to our existing firewall rules, which currently look like:
add action=accept chain=forward comment="Allow staff to ssh into devices on guest wifi" dst-port=22 in-interface-list=STAFF out-interface-list=GUESTWIFI protocol=tcp
add action=drop chain=input comment="defconf: drop all not coming from STAFF" in-interface-list=!STAFF log-prefix="DROP NOT STAFF"
add action=drop chain=forward comment="Drop all from DMZ not destined for WAN" in-interface-list=DMZ out-interface-list=!WAN
add interface=bridge-vlan20 list=DMZ
add interface=bridge-vlan30 list=STAFFWIFI
Those are just an excerpt of a few.
When moving to a single bridge instead, I’m not sure how I would rewrite those rules. If I rewrote them using IP addresses, someone could set an IP to another VLAN and access a service they shouldn’t, bypassing the firewall.
What is the recommended approach in this case?
IP Firewall rules is always on L3 interface level. Using firewall rules on a VLAN-aware L2 bridge (without an IP) will have no effect.
To protect people from “jumping between VLANs” enable vlan-filtering and frame-types=admit-only-untagged-and-priority-tagged on all client-ports.
I’m using VLAN aware bridge with sub-interfaces.
/interface vlan
add interface=bridge1 name=bridge1.55 vlan-id=55
add interface=bridge1 name=bridge1.57 vlan-id=57
add interface=bridge1 name=bridge1.58 vlan-id=58
add name=WAN
add name=LAN
add name=DMZ
add interface=bridge1.55 list=LAN
add interface=bridge1.57 list=DMZ
add interface=bridge1.58 list=WAN
As @mada3k already mentioned: populate your interface lists with appropriate vlan interface names and you’re all set, no need to rewrite firewall rules as long as they refer to interface lists …
E.g. if you previously had
/interface vlan
add interface=ether1 name=ether1_vlan20 vlan-id=20
add interface=ether1 name=ether1_vlan30 vlan-id=30
add name=bridge-vlan20
add name=bridge-vlan30
add bridge=bridge-vlan20 interface=ether1_vlan20
add bridge=bridge-vlan30 interface=ether1_vlan30
then you would now have something like
add name=bridge vlan-filtering=yes
add bridge=bridge interface=ether1
/interface bridge vlan
# the following two lines could be merged into one, but let's keep them separate for better reflection of old config
add bridge=bridge tagged=bridge,ether1 vlan-ids=20
add bridge=bridge tagged=bridge,ether1 vlan-ids=30
/interface vlan
add name=bridge-vlan20 interface=bridge vlan-id=20
add name=bridge-vlan30 interface=bridge vlan-id=30
# note that previously same names were used for bridges, now they are used for VLAN interfaces
You could use different names for vlan interfaces and if you set interface list members accordingly, the firewall rules would still remain intact.
