To all the experts in this forum, I need some help. For a couple of days I am fiddling around to get my RB2011 configured on my home network. Reading through the WIKI and the forum I got that far, the router does basically what it needs to do, but blocking me on the https access to the internet.
If I deacitvate the drop on the forward chain it works, but that shouldn’t be the solution. I am boggling my mind, but I don’t find what I am missing on. Maybe some of you genius can help me out.
Thanks in advance.
Here my config of the router:
add name=pv-bridge
add fast-forward=no name=vlan_bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether6 ] name=ether6-Config
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add interface=vlan_bridge name=vlan1 vlan-id=1
add interface=vlan_bridge name=vlan10-home1 vlan-id=10
add interface=vlan_bridge name=vlan20-home2 vlan-id=20
add interface=vlan_bridge name=vlan30-Gast vlan-id=30
add interface=vlan_bridge name=vlan40-VoIP vlan-id=40
add interface=vlan_bridge name=vlan60-Vsec vlan-id=60
add name=dhcp_pool_vlan1 ranges=192.168.1.100-192.168.1.200
add name=dhcp_pool_vlan10 ranges=192.168.11.10-192.168.11.99
add name=dhcp_pool_vlan20 ranges=192.168.12.10-192.168.12.99
add name=dhcp_pool_vlan30 ranges=192.168.13.10-192.168.13.99
add name=dhcp_pool_vlan40 ranges=192.168.14.10-192.168.14.20
add name=dhcp_pool_vlan60 ranges=192.168.16.100-192.168.16.200
add name=dhcp:pool_LAN70 ranges=192.168.17.10-192.168.17.20
add name=dhcp_pool_LAN5 ranges=192.168.5.2
add address-pool=dhcp_pool_vlan1 disabled=no interface=vlan1 name=dhcp_VLAN1
add address-pool=dhcp_pool_vlan10 disabled=no interface=vlan10-home1 name=dhcp_VLAN10
add address-pool=dhcp_pool_vlan20 disabled=no interface=vlan20-home2 name=dhcp_VLAN20
add address-pool=dhcp_pool_vlan30 disabled=no interface=vlan30-Gast name=dhcp_VLAN30
add address-pool=dhcp_pool_vlan40 disabled=no interface=vlan40-VoIP name=dhcp_VLAN40
add address-pool=dhcp_pool_vlan60 disabled=no interface=vlan60-Vsec name=dhcp_VLAN60
add address-pool=dhcp:pool_LAN70 disabled=no interface=pv-bridge name=dhcp_LAN70
add address-pool=dhcp_pool_LAN5 disabled=no interface=ether6-Config name=dhcp_LAN5
add bridge=pv-bridge interface=ether7
add bridge=pv-bridge interface=ether8
add bridge=pv-bridge interface=ether9
add bridge=pv-bridge interface=ether10
add bridge=pv-bridge interface=wlan1–PV
add bridge=vlan_bridge frame-types=admit-only-untagged-and-priority-tagged interface=ether2 pvid=60
add bridge=vlan_bridge interface=ether3 pvid=10
add bridge=vlan_bridge interface=ether4 pvid=20
add bridge=vlan_bridge interface=ether5 pvid=30
add bridge=vlan_bridge frame-types=admit-only-vlan-tagged interface=wlan2-Gast pvid=30
set discover-interface-list=none
/interface bridge vlan
add bridge=vlan_bridge tagged=vlan_bridge vlan-ids=1
add bridge=vlan_bridge tagged=vlan_bridge,ether3 vlan-ids=10
add bridge=vlan_bridge tagged=vlan_bridge,ether4 vlan-ids=20
add bridge=vlan_bridge tagged=vlan_bridge,ether3,ether5,wlan2-Gast vlan-ids=30
add bridge=vlan_bridge tagged=vlan_bridge,ether3,ether4,ether5 vlan-ids=40
add bridge=vlan_bridge tagged=vlan_bridge,ether3,ether5 vlan-ids=60
add address=192.168.1.1/24 interface=vlan1 network=192.168.1.0
add address=192.168.5.1/24 interface=ether6-Config network=192.168.5.0
add address=192.168.11.1/24 interface=vlan10-home1 network=192.168.11.0
add address=192.168.12.1/24 interface=vlan20-home2 network=192.168.12.0
add address=192.168.13.1/24 interface=vlan30-Gast network=192.168.13.0
add address=192.168.14.1/24 interface=vlan40-VoIP network=192.168.14.0
add address=192.168.16.1/24 interface=vlan60-Vsec network=192.168.16.0
add address=192.168.17.1/24 interface=pv-bridge network=192.168.17.0
/ip dhcp-client
add disabled=no interface=ether1-WAN
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.5.0/24 dns-server=192.168.5.1 gateway=192.168.5.1
add address=192.168.11.0/24 dns-server=192.168.11.1 gateway=192.168.11.1
add address=192.168.12.0/24 dns-server=192.168.12.1 gateway=192.168.12.1
add address=192.168.13.0/24 dns-server=192.168.13.1 gateway=192.168.13.1
add address=192.168.14.0/24 dns-server=192.168.14.1 gateway=192.168.14.1
add address=192.168.16.0/24 dns-server=192.168.16.1 gateway=192.168.16.1
add address=192.168.17.0/24 dns-server=192.168.17.1 gateway=192.168.17.1
set allow-remote-requests=yes
static add address=1.1.1.1 name=cloudflare
static add address=9.9.9.9 name=quad9
/ip firewall address-list
add address=192.168.5.0/24 list=mgmt
add action=accept chain=input comment=“accept established and related connections”
add action=fasttrack-connection chain=forward comment=“accept fast-track on established
and related connections” connection-state=established,related
add action=accept chain=forward comment=“accept established and related connections”
add action=drop chain=input comment=“drop invalid connections” connection-state=invalid
add action=drop chain=forward comment=“drop invalid connections” connection-state=invalid
add action=accept chain=input comment=“accept router configuration access” src-address-list=mgmt
add action=accept chain=forward comment=“allow admin access into all internal subnets”
dst-address=192.168.0.0/24 src-address-list=mgmt
add action=accept chain=forward comment=“accept ICMP requests for mgmt into internal
subnets (and internet)” in-interface=!ether1-WAN protocol=icmp src-address-list=mgmt
add action=accept chain=input comment=“accept ICMP requests only from inernal VLAN-LAN
users” dst-address=192.168.0.0/24 in-interface=!ether1-WAN protocol=icmp src-address=
192.168.0.0/24
add action=accept chain=input comment=“accept tcp DNS requests from internal users with
internet permission” dst-address=192.168.0.0/20 dst-port=53 in-interface=!ether1-WAN
protocol=tcp src-address=192.168.0.0/20
add action=accept chain=input comment=“accept udp DNS requests from internal users with
protocol=udp src-address=192.168.0.0/20
add action=accept chain=forward comment=“allow internet access for all relevant subnets”
dst-port=80 out-interface=ether1-WAN protocol=tcp src-address=192.168.0.0/20
dst-port=443 out-interface=ether1-WAN protocol=tcp src-address=192.168.0.0/20
add action=accept chain=forward comment=“access for VLAN10 members on PV-LAN” in-interface=
vlan10-home1 out-interface=pv-bridge
add action=accept chain=forward comment=“access for VLAN10 members on Vsec” in-interface=
vlan10-home1 out-interface=vlan60-Vsec
add action=accept chain=forward comment=“access for VLAN20 members on cameras in Vsec”
dst-address=192.168.16.16/28 in-interface=vlan20-home2 out-interface=vlan60-Vsec
add action=accept chain=forward comment=“access for VLAN30 members on cameras in Vsec”
dst-address=192.168.16.16/28 in-interface=vlan30-Gast out-interface=vlan60-Vsec
add action=drop chain=input comment=“DROP everything else on input chain”
add action=drop chain=forward comment=“DROP everything else on forward chain”
add action=masquerade chain=srcnat comment=“IP translation for VLAN-LAN with internet
permission only” out-interface=ether1-WAN src-address=192.168.0.0/20
