RouterOS Home Assistant MQTT Integration Tool
Overview
A powerful web-based generator tool for easily integrating MikroTik RouterOS devices with Home Assistant via MQTT protocol. This tool generates auto-discovery compatible scripts that seamlessly expose RouterOS metrics as Home Assistant entities.
Key Features:
Web-based configuration interface with real-time preview
Support for 30+ sensor types (temperature, CPU, memory, traffic, uptime, etc.)
Button and Switch control support with full MQTT command handling
Full Home Assistant MQTT Discovery protocol compatibility
Custom expression support for advanced metrics
Automatic entity discovery in Home Assistant
Built-in duplicate execution prevention
Complete debugging tools and troubleshooting guides
Supported Sensor Types
System Sensors
- uptime - System uptime in seconds
- board-name - Device model identification
- identity - RouterOS system identity
- free-memory - Available RAM (MB)
- total-memory - Total installed RAM (MB)
- cpu-load - CPU usage percentage
- cpu-count - Number of CPU cores
- temperature - System temperature (RB devices only)
- cpu-temperature - CPU temperature (RB devices only)
- voltage - System voltage reading (RB devices only)
Storage Sensors
- write-sect-total - Total write sectors (if supported)
- write-sect-since-reboot - Write sectors since last boot
- bad-blocks - Number of bad blocks detected
Network Sensors
- interface-count - Number of network interfaces
- bridge-count - Number of bridge interfaces
- gre-count - Number of GRE tunnels
- vlan-count - Number of VLAN interfaces
- ether-count - Number of Ethernet ports
- wireless-count - Number of wireless interfaces
Interface Traffic Monitoring
- rx-bits-per-second - Inbound traffic (bps)
- tx-bits-per-second - Outbound traffic (bps)
- rx-drops - Inbound dropped packets
- tx-drops - Outbound dropped packets
- rx-errors - Inbound transmission errors
- tx-errors - Outbound transmission errors
Control Types
- button - Momentary action triggers
- switch - Stateful ON/OFF controls
Quick Start Guide
Prerequisites
- RouterOS v7.1 or later with IoT package installed (iot.npk)
- Home Assistant with MQTT integration configured
- Mosquitto Broker or compatible MQTT broker
Step 1: Configure MQTT Broker in RouterOS
/iot mqtt brokers add \
name=homeassistant \
address=<YOUR_BROKER_IP> \
port=1883 \
username=<USERNAME> \
password=<PASSWORD> \
client-id=mikrotik-<SERIAL>
Step 2: Select Sensors
- Visit the web-based tool
- Choose your device model (hAP ax², RB4011, etc.)
- Select desired sensors from each category
- Configure Home Assistant Discovery Prefix (default: "homeassistant")
Step 3: Generate Main Script
- Click the MAIN SCRIPT tab
- Copy the generated RouterOS script
- Open Terminal in RouterOS WebUI (System → Terminals)
- Paste and execute the script
- Script will auto-configure and start publishing metrics
Step 4: Generate Subscription Scripts (for Button/Switch)
- If you selected Button or Switch controls:
- Go to SUBSCRIPTION tab
- Copy subscription commands
- Execute in RouterOS Terminal
- Subscriptions enable MQTT command handling
Step 5: Verify in Home Assistant
- Open Home Assistant → Settings → Devices & Services → MQTT
- New devices should appear under "mikrotik-{serial}"
- All selected sensors will be auto-discovered and available
- Configure automations and use sensors as needed
Step 6: Schedule Regular Updates (Optional)
/system scheduler add \
name=mqtt-update \
interval=30s \
on-event="/system script run mqtt-publish"
Feature Details
Auto-Discovery
The tool generates Home Assistant MQTT Discovery messages automatically. On first execution:
- Creates device entry in HA with manufacturer info, model, and firmware version
- Registers all selected sensors as individual entities
- Configures proper unit of measurement and device classes
- Sets up state topics for real-time updates
Main Script
Publishes selected sensor metrics at intervals:
- Uses global variables to avoid re-initialization
- Implements duplicate-execution prevention via script environment storage
- Collects all metrics and publishes via MQTT
- Configurable interval via scheduler (recommended: 5-30 seconds)
Subscription Script (Button/Switch)
Enables two-way communication:
- Button: Triggers actions on MQTT PRESS events
- Switch: Publishes state to
/statetopic, listens for ON/OFF commands - Full logging of received commands
- Extensible event handlers with TODO placeholders
Custom Expressions
Advanced users can define custom expressions:
[/ip address print as-value where interface=ether1 stats]
Expressions are pre-evaluated and cached for performance.
Debugging and Troubleshooting
Check Broker Connection
/iot mqtt brokers print
Look for connected=yes status.
View Active Subscriptions
/iot mqtt subscriptions print detail
Verify topic patterns match your configuration.
Debug Mode - Monitor All MQTT Traffic
/iot mqtt subscriptions add broker=homeassistant \
topic="homeassistant/#" \
on-message=":log info (\"Topic: \" . \$topic . \" | Data: \" . \$data)"
Then check logs: /log print where topics~"mqtt"
Remove Debug Subscription
/iot mqtt subscriptions remove [find topic="homeassistant/#"]
Force Configuration Refresh
Reset configuration tracking to force full re-discovery:
/system script environment remove [find name="configPublished"]
Execute main script again - it will re-send all discovery messages.
Advanced Configuration
Custom Sensor Expressions
Instead of predefined metrics, use RouterOS commands:
# Get highest CPU core temperature
[/system health print as-value count=1 | grep "temperature"]
Multiple Device Support
Generate separate scripts for different RouterOS devices:
- Use unique device names in Discovery Prefix
- Each device maintains independent script environments
- All devices publish to same MQTT broker
Filtering by Interface
Monitor specific interface traffic:
[/interface ethernet print as-value where name=ether1]
Common Issues & Solutions
Issue: Entities Not Appearing in Home Assistant
Solution:
- Verify MQTT broker is connected:
/iot mqtt brokers print - Check HA MQTT integration is enabled in Settings → Devices & Services
- Review HA MQTT logs for subscription errors
- Reset configuration:
/system script environment remove [find name="configPublished"] - Execute main script again
Issue: Metrics Not Updating
Solution:
- Verify scheduler is active:
/system scheduler print - Check script logs:
/log print where topics~"publish" - Ensure broker connection is stable
- Increase scheduler frequency temporarily for testing
Issue: Button/Switch Commands Not Working
Solution:
- Verify subscriptions exist:
/iot mqtt subscriptions print - Test subscription with debug mode (see Debugging section)
- Ensure on-message script has proper syntax
- Check /log for error messages:
/log print
Issue: High CPU Usage
Solution:
- Reduce scheduler frequency (increase interval to 30-60 seconds)
- Select fewer sensors to publish
- Use simpler expressions (avoid complex command chains)
- Check for infinite loops in custom expressions
Important Notes
Device Compatibility
- temperature and cpu-temperature are separate metrics (model dependent)
- Temperature, Bad Blocks, Voltage sensors only work on RB hardware
- write-sect-* sensors may not be available on all models
- Verify sensor availability on your device before configuration
Performance Considerations
- Publication interval: 5-30 seconds (recommended)
- Faster intervals increase CPU usage and MQTT traffic
- Each sensor requires one MQTT publish operation
- Disable unused sensors to improve performance
Duplicate Execution Prevention
- Script tracks configuration hash in script environment
- If configuration unchanged, skip discovery republish
- Automatic on each execution
- Manual reset available via script environment removal
Security
- Always use MQTT broker with authentication
- Consider using TLS/SSL for remote MQTT connections
- Protect RouterOS SSH access
- Regularly update RouterOS firmware for security patches
Tool URL
Access the web-based configuration tool and start generating your RouterOS MQTT integration scripts today!
http://www.routeros.cn/tool/iot.php
License & Attribution
This tool generates RouterOS scripts compatible with Home Assistant MQTT Discovery protocol. All generated scripts are yours to use and modify freely.
