Hi, I have the following setup:
=====> ADSL Modem ====> Linksys Router ====> LAN
The ADSL modem is configured as Half-Bridge, forwarding the public IP to the Linksys router WAN interface.
I want to replate the Linksys router with a RouterOS box, but for some reason it ignores the DHCP offer from the DSL modem.
I have captured the traffic between ADSL modem and the routers and mikrotik.
This capture is from Linksys:
No. Time Source Destination Protocol Info
189 43.818604 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x307da006
Frame 189 (590 bytes on wire, 590 bytes captured)
Ethernet II, Src: Cisco-Li_XX:XX:XX (00:14:bf:XX:XX:XX), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Internet Protocol, Src: 0.0.0.0 (0.0.0.0), Dst: 255.255.255.255 (255.255.255.255)
User Datagram Protocol, Src Port: bootpc (68), Dst Port: bootps (67)
Bootstrap Protocol
Message type: Boot Request (1)
Hardware type: Ethernet
Hardware address length: 6
Hops: 0
Transaction ID: 0x307da006
Seconds elapsed: 0
Bootp flags: 0x0000 (Unicast)
Client IP address: 0.0.0.0 (0.0.0.0)
Your (client) IP address: 0.0.0.0 (0.0.0.0)
Next server IP address: 0.0.0.0 (0.0.0.0)
Relay agent IP address: 0.0.0.0 (0.0.0.0)
Client MAC address: Cisco-Li_XX:XX:XX (00:14:bf:XX:XX:XX)
Client hardware address padding: 00000000000000000000
Server host name not given
Boot file name not given
Magic cookie: (OK)
Option: (t=53,l=1) DHCP Message Type = DHCP Discover
Option: (t=61,l=7) Client identifier
Option: (t=12,l=7) Host Name = "WRT54GS"
Option: (t=60,l=12) Vendor class identifier = "udhcp 1.14.4"
Option: (t=57,l=2) Maximum DHCP Message Size = 576
Option: (t=55,l=7) Parameter Request List
End Option
Padding
194 45.820354 0.0.0.0 XXX.XXX.XXX.XXX DHCP DHCP Offer - Transaction ID 0x307da006
Frame 194 (320 bytes on wire, 320 bytes captured)
Ethernet II, Src: Comtrend_XX:XX:XX (00:30:da:XX:XX:XX), Dst: Cisco-Li_XX:XX:XX (00:14:bf:XX:XX:XX)
Internet Protocol, Src: 0.0.0.0 (0.0.0.0), Dst: XXX.XXX.XXX.XXX (XXX.XXX.XXX.XXX)
User Datagram Protocol, Src Port: bootps (67), Dst Port: bootpc (68)
Bootstrap Protocol
Message type: Boot Reply (2)
Hops: 0
Seconds elapsed: 0
Your (client) IP address: XXX.XXX.XXX.XXX (XXX.XXX.XXX.XXX)
Magic cookie: (OK)
Option: (t=53,l=1) DHCP Message Type = DHCP Offer
Option: (t=54,l=4) DHCP Server Identifier = 0.0.0.0
Option: (t=51,l=4) IP Address Lease Time = 30 seconds
Option: (t=1,l=4) Subnet Mask = 255.255.255.252
Option: (t=3,l=4) Router = XXX.XXX.XXX.XXX
Option: (t=6,l=8) Domain Name Server
End Option
195 45.821958 0.0.0.0 255.255.255.255 DHCP DHCP Request - Transaction ID 0x307da006
Frame 195 (590 bytes on wire, 590 bytes captured)
Bootstrap Protocol
Hops: 0
Seconds elapsed: 0
Magic cookie: (OK)
Option: (t=53,l=1) DHCP Message Type = DHCP Request
Option: (t=50,l=4) Requested IP Address = XXX.XXX.XXX.XXX
End Option
Padding
196 45.823468 0.0.0.0 XXX.XXX.XXX.XXX DHCP DHCP ACK - Transaction ID 0x307da006
Frame 196 (320 bytes on wire, 320 bytes captured)
Bootstrap Protocol
Hops: 0
Seconds elapsed: 0
Magic cookie: (OK)
Option: (t=53,l=1) DHCP Message Type = DHCP ACK
End Option
This capture if from RouterOS:
6 0.577866 0.0.0.0 255.255.255.255 DHCP DHCP Discover - Transaction ID 0x9b05bfa5
Frame 6 (342 bytes on wire, 342 bytes captured)
Ethernet II, Src: Routerbo_XX:XX:XX (00:0c:42:XX:XX:XX), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Bootstrap Protocol
Hops: 0
Transaction ID: 0x9b05bfa5
Seconds elapsed: 55
Bootp flags: 0x8000 (Broadcast)
Client MAC address: Routerbo_XX:XX:XX (00:0c:42:XX:XX:XX)
Magic cookie: (OK)
Option: (t=55,l=6) Parameter Request List
Option: (t=12,l=8) Host Name = "MikroTik"
End Option
Padding
7 0.579170 0.0.0.0 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x9b05bfa5
Frame 7 (316 bytes on wire, 316 bytes captured)
Ethernet II, Src: Comtrend_XX:XX:XX (00:30:da:XX:XX:XX), Dst: Broadcast (ff:ff:ff:ff:ff:ff)
Bootstrap Protocol
Hops: 0
Seconds elapsed: 0
Your (client) IP address: 192.168.1.2 (192.168.1.2)
Magic cookie: (OK)
Option: (t=51,l=4) IP Address Lease Time = 10 seconds
Option: (t=1,l=4) Subnet Mask = 255.255.255.0
Option: (t=3,l=4) Router = 192.168.1.1
Option: (t=6,l=4) Domain Name Server = 192.168.1.1
End Option
Frame 9 (342 bytes on wire, 342 bytes captured)
Bootstrap Protocol
Hops: 0
Seconds elapsed: 57
Magic cookie: (OK)
End Option
Padding
10 2.618902 0.0.0.0 255.255.255.255 DHCP DHCP Offer - Transaction ID 0x9b05bfa5
Frame 10 (316 bytes on wire, 316 bytes captured)
Bootstrap Protocol
Hops: 0
Seconds elapsed: 0
Magic cookie: (OK)
End Option
The diference between them is that Mikrotik sets the broadcast flag, so the server sends the offer to FF:FF:FF:FF:FF:FF but RouterOS ignores it.
Please help! ![]()
