RouterOS in the proxmox?
Hi there
I have to replace the old router with some new solution and currently looking around. Thinking to go that way: some server with one or two Xeon 6148 or more core first gen scalable CPU and 25gbps cards. Probably it should work well on bare metal but is the idea to run the Routeros 7 in the proxmox good? Can I just pass the network cards to the ROS VM and use them directly?
You might be interested to follow this discussion as well:
http://forum.mikrotik.com/t/third-party-x86-hw-ros-support/183561/26
Mikrotik haven’t migrated all info from the old wiki.
https://wiki.mikrotik.com/Manual:CHR_ProxMox_installation
