I’ve setup at least 10 MikroTik routers or switches. They all “just work” without a problem. But, I can’t get the newest one to work.
The newest (problem) unit is a RB2011UiAS-2HnD-IN that is connected v1a ETH1 to an already established hAP lite. After powering up the problem unit display shows
local ip: 192.168.88.1
ether1: 192.168.1.196 - this is a wireless connection that comes from the dhcp server in the network
Running WinBox on the hAP lite
- the problem unit isn’t shown as a neighbor to the hAP lite
- the Interface List shows bytes being transmitted to the problem unit
- running ping on 192.168.1.196 works with 0 or 1 ms. Also, the Interface shows bytes to and from problem unit.
- running ping on 192.168.88.1 doesn’t work
Submitting 192.168.1.196 to IE, Chrome or Safari on an iPad doesn’t get anywhere - just times out with no WebFig showing.
I’ve tried turning off Avast.
What am I missing
