RouterOS isn't available for TheDude.
Is RouterOS required for TheDude to function? I took over a network that had no documentation. I can access TheDude’s Web Portal, but the RouterOS tab is blank when I click it. We’re thinking about upgrading to V6, but we’re not sure how to do so without RouterOS. Please let me know if you know how to find the IP address. Thank you very much!
There are two versions of TheDude. One runs in RouterOS. Another is a standalone application running on Windows that talks to the MikroTik and RouterOS devices.
You can go here:
https://mikrotik.com/download
Then click on the TheDude drop down and select which stability you would like to download and install on Windows.
The Web Portal of The Dude is only on old 4.x version running ONLY on Windows (for the others: and VM, ok, but tis is not the point)
If you see the web portal, you have already the IP, not?
Version v6 work ONLY on RouterBOARD with RouterOS (for the others: and CHR or x86 on VM, ok…)
If you install “The Dude” Client on Windows… install only the Client… the server must be on RouterOS
There are no compatibility between the two version (and also between same v6 version…)
