Hello everyone. This deployment is for my homelab and I have no production services. No real impact other than a few upset kids that can’t get to their internal minecraft server from wifi.
I’m brand new to MikroTik; however, I’ve been working with network devices for quite a while. I’m moving away from a design that used the UniFi USG for L3 inter-vlan routing to a CRS326 running RouterOS v7.7. The main reason for this new design is to offload inter-vlan media server streaming traffic from the USG by keeping it within the CRS326. I also needed a few extra ports.
I thought everything was working as expected until I started to connect my WAPs. Did some troubleshooting for a bit and after testing VLAN tagging from a VM, I have narrowed down the issue to tagged VLANs not passing traffic if they’re not assigned PVID on trunk ports.
My test was to create a VM using VLAN20 on an vSphere host on ether21,22. No DHCP. Configured static address and can not reach VLAN20 gateway.
The host is currently connected via tagged management network and the existing VMs inside are tagged VLAN25 as well.
I can ping VLAN20 gateway from a computer on access port (untagged) ether3.
en9: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6467<RXCSUM,TXCSUM,VLAN_MTU,TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether 60:32:b1:23:a8:2e
inet6 fe80::c17:209f:530b:3ab4%en9 prefixlen 64 secured scopeid 0xd
inet 192.168.17.107 netmask 0xffffff00 broadcast 192.168.17.255
nd6 options=201<PERFORMNUD,DAD>
media: autoselect (1000baseT <full-duplex>)
status: active
$ ping 192.168.20.1
PING 192.168.20.1 (192.168.20.1): 56 data bytes
64 bytes from 192.168.20.1: icmp_seq=0 ttl=64 time=0.471 ms
64 bytes from 192.168.20.1: icmp_seq=1 ttl=64 time=0.698 ms
64 bytes from 192.168.20.1: icmp_seq=2 ttl=64 time=0.655 ms
64 bytes from 192.168.20.1: icmp_seq=3 ttl=64 time=0.617 ms
^C
--- 192.168.20.1 ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.471/0.610/0.698/0.085 ms
Configuration
# feb/18/2023 13:40:39 by RouterOS 7.7
# software id = INT8-8NDU
# model = CRS326-24G-2S+
# serial number = <redacted>
add admin-mac=48:A9:8A:0F:26:E8 auto-mac=no comment=defconf name=bridge
add name=bridge1 pvid=25 vlan-filtering=yes
set [ find default-name=ether21 ] l2mtu=9216 mtu=9000
set [ find default-name=ether22 ] l2mtu=9216 mtu=9000
set [ find default-name=ether23 ] l2mtu=9216 mtu=9000
set [ find default-name=ether24 ] l2mtu=9216 mtu=9000
/interface vlan
add interface=bridge1 name=VLAN17 vlan-id=17
add interface=bridge1 name=VLAN20 vlan-id=20
add interface=bridge1 name=VLAN25 vlan-id=25
/ip hotspot profile
/port
set 0 name=serial0
add bridge=bridge1 comment=WAP01 interface=ether2 pvid=25
add bridge=bridge1 comment=defconf interface=ether3 pvid=17
add bridge=bridge1 comment=defconf interface=ether4 pvid=17
add bridge=bridge1 comment=defconf interface=ether5 pvid=25
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface=ether17
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge1 comment="esx-node01 - vkernel" interface=ether21 pvid=25
add bridge=bridge1 comment="esx-node01 - vkernel" interface=ether22 pvid=25
add bridge=bridge1 comment="NAS Adapter 3" interface=ether23 pvid=25
add bridge=bridge1 comment="NAS Adapter 4" interface=ether24 pvid=25
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=sfp-sfpplus2
/interface bridge vlan
add bridge=bridge1 tagged=bridge1 untagged=ether3,ether4 vlan-ids=17
add bridge=bridge1 tagged=bridge1 vlan-ids=20
add bridge=bridge1 tagged=ether21,ether22 untagged=bridge1 vlan-ids=25
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.17.1/24 interface=VLAN17 network=192.168.17.0
add address=192.168.15.2/29 interface=ether1 network=192.168.15.0
add address=192.168.20.1/24 interface=VLAN20 network=192.168.20.0
add address=192.168.25.1/24 interface=VLAN25 network=192.168.25.0
/ip dhcp-relay
add dhcp-server=192.168.25.101,192.168.25.102 disabled=no interface=VLAN17 name=VLAN17
add dhcp-server=192.168.25.101,192.168.25.102 disabled=no interface=VLAN20 name=VLAN20
set servers=192.168.25.101,192.168.25.102
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.15.1 pref-src="" routing-table=main suppress-hw-offload=no
/system clock
set time-zone-name=<redacted>
/system routerboard settings
set boot-os=router-os
Network diagram:
I need help with the trunk on ether21,22. I know my UniFi WAPs need a hybrid port (trunk with native VLAN) and I can take care of that once tagging is working as expected on ether21,22. I’ve read several posts and I thought I had it until I went to test wifi.
Thanks in advance. ![]()
