I want to deploy a system that will serve PPPoE connections (approx 600 users) and will be a firewall.
The server I want to use is a HP Proliant DL 360 G3 - Dual Xeon 2 X 2.8 Ghz/ 2GB ram
Do you find it suitable ?
Also I’ll remove the SCSI disks and will boot from IDE flash. Do you see any problem about this ?
It depends of amount of traffc you suppose to run through the firewall and its rules.
In my option this setup is able to manage cca 200Mbit constant throughput but again - it depends.
As many dynamic firewall rules (like dynamic addresslists etc) as many CPU and RAM consumption.
What purpose is this firewall supposed to serve?
cheers
Patrik
