RouterOS on common hardware
Hi all!
I wounder if it’s possible to install RouterOS on a Buffalo WZR-HP-AG300H with Atheros AR7161 chipset?
I would like to test some wifi features before I replaces the wifi core at home with our hardware.
//Robbs
most probably no. Only common hardware you can use is x86
RouterOS is supported only on X86 PCs and RouterBOARD ™ hardware
RouterOS on UBQ units :slight_smile:
