Hello:
I am experiencing some issues with an OpenVPN server deployment running on RB4011iGS+ with RouterOS v6.48.6 and level 5 license
The router is managing about 150 OpenVPN clients but about once a day it gets stuck, some connections continue working, and other clients get disconnected. OpenVPN port is reachable but clients can’t connect until I reboot the router.
I don’t know if the issue is related to the capacity of the routerboard but I can’t see too much resource consumption, load is pretty low: average CPU is 3% and RAM 70 MiB.
Throughput in the WAN interface also seems normal: less than 1 Mbps Tx, 400 kbps Rx
OpenVPN logs don’t show anything abnormal.
Is the RB hardware enough to manage the number of clients? I guess if it were a hardware/capacity problem I would notice a higher resource usage, wouldn’t I?
Any help to debug what is going wrong?
Thanks in advance
