Hi erveryone !
I am currently encountering a problem.
When I want to download a file on a mikrotik in 6.48.6 using mtlogin and fetch tool, it works perfectly and the script waits until the router has finished downloading to send a “quit”.
However, when trying the same manipulation on a router with version over 6.48.6, the “quit” is sent directly, thus stopping the download because of the letter Q and thus sending “uit” thereafter in the prompt.
The prompts are similar for 6.48.6 and over, and even when trying to add expects in the script, the result is the same. I think the problem is in this part of the code, but don’t know how to fix it.
# Run commands given on the command line.
proc run_commands { prompt command } {
global do_interact in_proc
set in_proc 1
# escape any parens in the prompt, such as "(enable)"
regsub -all "\[)(]" $prompt {\\&} reprompt
# handle escaped ;s in commands, and ;; and ^;
regsub -all {([^\\]);} $command "\\1\u0002;" esccommand
regsub -all {([^\\]);;} $esccommand "\\1;\u0002;" command
regsub {^;} $command "\u0002;" esccommand
regsub -all {[\\];} $esccommand ";" command
regsub -all {\u0002;} $command "\u0002" esccommand
set sep "\u0002"
set commands [split $esccommand $sep]
set num_commands [llength $commands]
for {set i 0} {$i < $num_commands} { incr i} {
send -- "[subst -nocommands [lindex $commands $i]]\r"
if { [lindex $commands $i] == "/system/reboot"} {
send "y\r"
expect {
-re "^\[^\n\r]*$reprompt" {}
-re "^\[^\n\r ]*>>.*$reprompt" { exp_continue }
-re "\[\n\r]+" { exp_continue }
if { $do_interact == 1 } {
interact
return 0
send "quit\r"
expect {
-re "^WARNING: There are unsaved configuration changes." {
send "y\r"
exp_continue
"\n" { exp_continue }
"\[^\n\r *]*Session terminated" { return 0 }
timeout { catch {close}; catch {wait};
return 0
eof { return 0 }
set in_proc 0
That’s how it looks like:
Does anyone have a solution?
