RouterOS performance with IP firewall rules
Hi all,
I am new to RouterOS and have a CCR1016. Hope, any experts out there can answer questions below.
First, I need CCR1016 to do the following tasks:
1- 1 binding interface (LACP) to the firewall.
2- 2 binding interfaces (LACP ) to D-Link switches. Each binding interface is carrying 3 VLANs.
3- VLAN_1 from bind_switch1 can connect to VLAN_1 from bind_Switch2. vice versa.
VLAN_2 from bind_switch1 can connect to VLAN_2 from bind_Switch2. vice versa.
VLAN_3 from bind_switch1 can connect to VLAN_3 from bind_Switch2. vice versa.
4- Configure an IP on the binding interface and set default route to the firewall/Internet
5- VLAN_1 from any interface can connect to VLAN_2 and VLAN_3
VLAN_2 or VLAN_3 CANNOT initiate connection to VLAN_1
Then with configuration,
A. I am able to create 3 binding interfaces so #1 and #2 task are ok
B. I am able to create 3 bridges for each VLAN so #3 task is ok
(bridge1 interfaces: vlan1_bindSwitch1, vlan1_bindSwitch2)
(bridge2 interfaces: vlan2_bindSwitch1, vlan2_bindSwitch2)
(bridge3 interfaces: vlan3_bindSwitch1, vlan3_bindSwitch2)
C. I am able to add default route to firewall’s IP so #4 is ok
D. I able to use IP firewall to allow only VLAN1 established traffic to VLAN2 and VLAN3 but… I encountered is that by “IP firewall”… CPU usage is high (80-95%) and throughput is not as good (10-20% less) as without IP firewall configured.
My questions are…
1- Is my way of configuration (using bridge for each vlan to connect to 2 trunk to 2 switch) the correct way to do this?
2- IP firewall uses CPU therefore the performance is lower since RouterOS is software based?
Hope any RouterOS can help me!
Thanks in advance,
Douglas
Hi all,
My questions are…
Thanks in advance,
Douglas[/quote]
p.s. I attached a diagram that may help explain what I am trying to accomplish and a copy of current configuration.
MikroTik CCR-1036-12G-4S config04302015.rtf
