Hi All,
I was wondering if anyone could shed some light on a problem I
have with RadiusManager (1) and a medium-sized wifi network
(fully routed) all running MikroTik Router OS (of varying versions)
and using RouterBoard hardware.
The problem is, since upgrading to the latest version of RadiusManager
version 3.7.0 automatic disconnections of pre-paid users
do not work, neither do manual disconnections via the
ACP (Admin Control Panel). Neither methods “NAS” nor
“Remote” methods work .
I’m uncertain what other information I should provide for the
moment, but if anyone might have some insight, please reply
to this post and help me solve this! (Sadly DMA Soft Lab are
unhelpful and will only provide technical support in the form
of remote fixes without advising you of the problem or it’s
solution …).
Thank you,
cheers
James
- http://www.dmasoftlab.com/cont/home
Hi all,
Just an update to this Issue.
After some helpful advice from DMA Soft Lab and some
debugging of my own, I’ve been able to work out that
this in fact might be a problem with MikRoTik Router OS
My problem seems to be related to this thread:
http://forum.mikrotik.com/t/os-4-7-dhcp/37166/1
I get these messages in the radius,debug logs for the NAS
in question:
16:12:17 radius,debug received remote request from 172.16.0.1:1258 with unknown address, dropping
16:12:22 radius,debug received remote request from 172.16.0.1:1258 with unknown address, dropping
16:12:27 radius,debug received remote request from 172.16.0.1:1258 with unknown address, dropping
The solution however eludes me and is not the same as the thread above.
Any ideas ?
cheers
James
FYI, we can get this (POD) to work on only 1 of our NAS.
echo "User-Name=28_1a" | radclient -x 10.0.0.2:1700 disconnect ...
Sending Disconnect-Request of id 44 to 10.0.0.2 port 1700
User-Name = "28_1a"
rad_recv: Disconnect-ACK packet from host 10.0.0.2 port 1700, id=44, length=31
NAS-Identifier = "ap1"
NAS-IP-Address = 10.0.0.2
This particular NAS however is on teh same subnet as our Radius
Server. The other NASes in our network are not.
cheers
James
This might be a tad late but i can sympathise with you as i’m experiencing same issue with radius manager and mikrotik.I think it seems to be the case if the subnet differs from the subnet in which your radius manager resides.When i create a pppoe server on the radius manager’s lan the remote disconnect packets come through perfectly.All my highsites connect to my radius manager via pptp tunnels and authentication etc works perfectly except remote disconnect packets.interim updates have been set to 1 minute intervals and for the life of me i can’t understand why it shouldn’t work.Will have to sleep on it and perhaps the answer might spring to mind
Hi
i am having the same problem on my mikrotik ospf network. Is there a solution to this ?
thanks
ok found a tempory fix.Hopefully one of the experts can shed some light.
The error i was getting was:
16:12:17 radius,debug received remote request from 10.0.2.1:1258 with unknown address, dropping
this error was generated from router ip 10.0.2.2 when my client was supposed to be disconnected from PPPOE session
My ospf network is as follows
10.0.2.2------10.0.2.1---------10.0.48.1----------10.0.48.2______________10.0.200.1_____________10.0.200.2(freeradius)
Router1-------Router2----------Router3-----------Router4(ETH1)_________Router4(ETH2)_____________RADIUS BOX
TEMP FIX
i added a second radius server in mikrotik 10.0.2.1 First radius obviously 10.0.200.2
