RouterOS releases
Please, give me a link to site with all releases… Need 6.0. Can’t find.
why do you need 6.0? it contains issues that are fixed in v6.1.
We have IPSec issues…
Try this newer version where some Ipsec issues are fixed: http://www.mikrotik.com/download/share/all_files_6.2.zip
I added files but can’t upgrade with The Dude: “no packages available”.
Did you also try “force upgrade” in the Dude ?
The same error. I saw “upgrade package” in the other package groups… Didn’t find in the your archive.
ok try this then
http://www.mikrotik.com/download/share/routeros-mipsbe-6.2.npk
http://www.mikrotik.com/download/share/routeros-x86-6.2.npk
Thank’s. Now I can upgrade up to 6.2.
IPsec with multiple peers is fixed in the latest v6.2 build (20 min ago). please test if you had this issue
Now it’s working. We are monitoring the situation… Thank’s a lot.
