I am testing /interface/pppoe-server/remove via the API, which means I am calling it over and over.
I noticed that when I first boot my MikroTik, I can manually kick my PPPoE user without issue – note this is interactive:
[admin@BOMA_lab] > /ppp active print
Flags: R - radius
# NAME SERVICE CALLER-ID ADDRESS UPTIME ENCODING
0 R andristhe... pppoe D4:CA:6D:04:C0:14 0.0.0.0 51s
[admin@BOMA_lab] > /interface pppoe-server remove
numbers: 0
…works great, the user’s PPPoE session restarts.
After hitting the API maybe 20+ times (i.e. testing my own code), something goes awry in RouterOS. Note this is another interactive prompt, doing the same as above – but different results:
Flags: R - radius
0 R andristhe... pppoe D4:CA:6D:04:C0:14 0.0.0.0 5m13s
numbers: 0
no such item (4)
I’ve seen this on 6.20 and 6.27.
