Hi all,
I have a speed issue with my CRS328-24p-4s+rm, when connected via SFP+ ports.
I have a server connected via SFP+ Fiber cable (10Gbps) to the crs328-24p-4s+rm and a direct copper link to the ISP Router (1Gbps).
I realized some internal speed problems and if I do a basic Internet speed test, the Download speed is between 3-6 Mbps when executed from the Server (or any other device connected via SFP+)? If i connect the server via normal Copper RJ45 cable, the Internet Speed is maxed out.
Just for further testing, i switched the OS to SWOS, and there I have no issues with the Fiber SFP+ ports.
Is there any setting in RouterOS, which need to be de/activated?
crs328-24p-4s+rm
RouterOS: 6.45.2
I reset the configuration, so no additional settings are active…
Thanks in advance for your help.
