Hi All,
I wish to setup a simple WireGuard client on my router (hAP ax lite LTE6) that will give me a static external ip address from the host network.
I can get this working very simply on my windows laptop with the WireGuard Windows app by importing the below config file, but need this to be running on the router for all connected clients:
etc. etc.
and have reset the router to factory defaults multiple times, but still no joy I’m afraid.
The router does have internet connectivity when default with a working data sim.
End goal is that any client connected to wifi or lan will have access to the internet and the router/clients will have an external IP of “DesiredExternalIPAddress”.
Not really enough info.
It would seem you are saying you have purchased a third party VPN provider and wish to use that provider for internet access for some or all of the users on your router.
In other words the router is not the server for handshake but he wireguard client for handshake?
OR
You are connecting to another router???
One can conclude this by your opening statement: simple WireGuard client on my router (hAP ax lite LTE6)
In terms of setup, this is actually what it should look like, no offense to the previous poster but its in error.
One should be careful before providing bad information!!!
/interface wireguard
add listen-port=51820 name=wireguard1 { port can be anything random no relation to port given to you by third party provider etc. }
/interface wireguard peers
allowed-address=0.0.0.0/0 { so your users can use internet through turnnel } , endpoint-address=publicIP of third party device or provider, endpoint-port=Port given by third party provider }DesiredEndpointPort interface=wireguard1 public-key=CorrectPublicKey { provided by third party device or provider }
persistent-keep-alive=35s { to ensure your router keeps the tunnel open }
add address=WireguardSubnet-ClientAddress/24 interface=wireguard1 { given to your by third party provider }
NOT required for the general wireguard subnet however we will add one for Sending local traffic on the router into the tunnel.
dst-address=wireguard subnet gateway=wireguard1 { this is created automatically by the router when you create the IP address for wireguard }
add chain=input NOT REQUIRED, the router is not the servers for handshake…
Okay that gets you to solid place to now consider how to force traffic into the tunnel. You will need three things..
a. firewall rule to allow traffic to enter tunnel ( permission function )
b. add table to use for our route setup
c. decide to use either mangling or routing rules for catching/forcing traffic into tunnel
d. ensure we source nat all traffic entering tunnel with WG ip address given to you by the third party provider as a their end they will not accept any other source IPs. !!
Will have to see your current full config to make any more recommendations.
PS where do you see to enter DNS on the mikrotik wireguard interface settings, not any such thing on my router ???
What DNS did the third party provider give you???
Sure.
Think about it. The 3rd party VPN provider gives you ONE, a single IP address for wireguard.
Therefore all traffic, coming from the MT, with source address that is NOT that single address will be dropped, when it shows up at the 3rd party peer Server.
Similar to NAT, how all private LAN traffic leaving the router is given the source address of the WANIP, and thus appears as a single address to all recipients.
This is accomplished by the sourcenat rule. add chain=srcnat action=masquerade out-interface-list=WAN
The same needs then to be applied to all traffic leaving the router and entering the tunnel (interface=wireguard1) for the other end 3rd party processing.
Hence we have two option to accomplish this:
A. add another sourcenat rule. add chain=srcnat action=masquerade out-interface=wireguard1
B. add the wireguard interface as a WAN interface list member, and THEN the default rule above, automatically includes all outgoing traffic through the list interfaces (aka has the same functionality of the the additional rule). /interface list member add interface=wireguard1 list=WAN
