RouterOS stop working with a Server PPPoE in RC13
Hello everybody
I’m using a Server IBM, with 1 GB of RAM and a processor of Dual 2 Core, with RC13 to serve 150 pppoe connections.
But it have a problem, randomly the RouterOS stop works!! I can’t see the router via network, and I tried ingress via console, and nothing. The only way that it respond is to shutdown and start it again!!
I activated the Watchdog system, but it didn´t works. I enable the graphing and I see that everything stop, there is not use of processor, Ethernet, nothing!!!.
Another thing that I tried is to make an script that count the number of pppoe connections and when it is 0, the script reboot the server. But as the Server is idle, is not executed.
Thank
Rafael Lore
do you use web-proxy?
Hi Chupaka !!
Yes I’m using Web-Proxy. Also PPPoE server, Mangle with Layer 3 and 7, and Queue tree
Do you think that the Web-Proxy is the problem?
Regards,
Rafael Lore
try disabling web-proxy. in v3.0, web-proxy hangs the router (well, my last router with RC13 just reboots =) )
Problem RESOLVED!!!
Janis told that I had to disable multi-procesor and tried without Layer 7, and now is working PERFECTLY, since 2 day I don’t have any problems!!!
Thanks everybody
Rafael Lore
