I d’like to say if I can buy Gigabyte AirCruiser PCIe (Atheros shipset ). If RouterOs support mini-pci express
what chipset is the card? I think RouterOS does support some cards in this standard, but it depends on the chipset actually
The Atheros chipset for this mini-PCIe is AR5006EGS = AR2424 (GN-WI01GT) or AR5007EG = AR2425 (GN-WS50G-RH)
what chipset is supported on the mini-PCIe port?
Here is the chipset that appear to be supported
non-exhaustive list
AR5006X = (AR5413)
AR5006XS = (AR5414)
AR5004X = (AR5213 + AR5112)
AR5004G = (AR5213 + AR2112)
Are these supported now? I have one.
will there be a low-cost routerboard in the future that fully supports mini-pci-express?
or: are there any 3-chain 802.11n mini-pci (non-express!) cards that supports up to 450mbps air-rate?
exist. i seen some on ebay in minipci with 3 chains, but what for use them, if RB without mini pci-e anyway just 100mbps ![]()
RB435G, RB493G, RB433GL
rb600, rb800
