There is a wiki page with the user tested hardware, but it’s not very popular. Let’s make this page useful and add tested stuff in there - you will help others, and others will help you!
It is really great idea, especially for collecting multi-core working hardware, but I think it will be much easier if we will have command like “dmesg”.
More of a question, but it seemed appropropriate in this thread. Is there any planned support for current DS3 PCI hardware? I imagine that there probably isn’t very much demand for DS3 hardware these days, but it would be a tremendous benefit to us as we’ve got multiple DS3-fed locations that we’re forced to use Cisco hardware at; we greatly desire to use MT where ever we can. Thanks!
I have MB elitgroup P35T-A and MT 3.7, its working fine, but integrated network adapter Intel 82566DC GigaLAN is not detected, is it possible to install driver?
If yes, can some one link me wher to find drivers for MT?
Normis, there exists the possibility of adding methods of balancing of connections in the NAT? Example: Round Robin, Auto-Weight, weight weighted, and other. This is very important for ISPs.
Best Regards
Paul.
What kind of information would be useful in the wiki on supported hardware?
Maybe some of the more experienced MikroTik users could chip in on this? Maybe even add a template for useful fields in the wiki?
FCC ID on wireless cards can come in handy when doing research on hardware.
Number of PCI slots.
Chipset on motherboards.
NIC chip. - support 1500+ packet?
IDE or SATA support.
Any suggestions on a test procedure on x86 hardware?
no test procedure, I think the best would be to speak from personal experience - if you have used this chipset for a while, you can add it to the list with note that it works fine. something like that.
I have MB asus p5kc,Do you know when routeros can support Pata controller?
or never support? If it’s worth watting for routeros or i need change to another MB?
can you give me some advices?
thanks very much.
–my motherboards below
ASUS P5KC (Intel P35, 3x PCI, 3xPCI-E) 3.10 Not supported PATA controller (JMicron JMB363), ROS can boot from USB flash drive; internal ethernet not recognized.
