I’m unable to find an answer and all my tests were inconclusive: can RouterOS act as a syslog server ?
Thank you
Thank you
No. Unless you install the dude. But it has too much problems itself.
You can’t use RouterOS as a syslog server.
However, you can install OpenWRT in MetaROUTER. It is possible to run syslog server and many other applications on OpenWRT.
Unfortunatelly virtualized os does not have access to usb disk files, so you cannot store the logs directly to external flash.
I already was asking here on the forum more than year ago the same question: http://forum.mikrotik.com/t/remote-logging-from-one-mikrotik-to-another-mikrotik/70456/1
I also argumented that syslog server would be much more useful than ip cloud. http://forum.mikrotik.com/t/ip-cloud/77987/13 No answer to this.
You should search the forum before you asked.
Anyway, now I do not think it is necessary when running dude on pc. Unfortunatelly it needs running pc. I hope I will deploy some small mipsbe devices with 5.x ros and try to run dude on them. Hope it will work. In this case I would be able to get rid of dude from pc.
Have a look at dude, it has quite good syslog server functionalities.
Thank you for your answer.
Thank you - I did install OpenWRT as a mean to have a full implementation of OpenVPN ![]()
I finally used my NAS as syslogd and had everything logged there.
Thanks for giving me such a good advise
However I did search the forum and used my friend Google and oddly enough , even using right terms “syslog syslogd server”, I only found threads and people discussing having RouterOS send logs to another host.
Installing Syslog on MT?
In this case I think this would kill CPU!!!
Not by syslog server itself as it already works like part of dude package that does much more heavy things over the syslog server.
Maybe file operations on USB storage is able to kill cpu as it is very inefficiently implemented in ROS / RB hardware (do not kno exactly what is the bottleneck, but to operate with files on USB flashdisk is nightmare for Routerboards according to my experience). I guess that this is also the reason why dude runs so badly on RB.
