i had purchased the new RB750UP (equipped with USB port). After i have tested the USB port for connecting 3G modem Huawei K3765 (and works) i had decided to use and test the same port with an flash drive.
After configuration and format process the driver was seen by the system. The next step was to configure the ftp server to copy something on it. For that had used the ftp protocol to access and copy file on it.
The issue that i had discovered; after i had reboot the device, the directory ( folders as we know in windows) copied on it disappear.
What i mean ?
So using an ftp client i had copy and iso file on it, reboot the router the file still present.
Following the same steps but this time copy an entire directory (folders as we know in windows), after reboot the entire directory has disappeared.
So experts where is the issue if exist .
Best Regards,
Daniel
PS:
RB750UP with 5.11 on it ( updated on last version ) current firmware 2.37
After ROS 5.12 i tried to use smb server on RB751U-2HnD but after a reboot - all my files are deleted
Same problem was when I used flash drive as FTP server
(RB751U-2HnD with ROS 5.12, flash drive Kingston 8GB (tried and Transcend 16GB))
hi im fairly new to this, so i was wondering what kind of parameters i have to adjust to be able to use external 200gb hdd in mikrotik 751 usb port? like which options to click. thanks in advance. i guess i also need to update from 5.16 to 5.20 to not get files deleted. is it resolved in the last version? tnx for the infos
First you need activate your storage
/store> add name=some_name disk=disk1 type=user-manager activate=yes
you also can select another options - http://wiki.mikrotik.com/wiki/Manual:Store
After format - is ready
Can I use user manager to store it’s database in an external HDD/Flash Drive connecting it with Micro usb port of RB2011 UAS-RM?
I am Planning to purchase Level6 license.
will the performance of the user manager will be good enough and be a best alternative for aptilo/inventum?
Any real time experience?
Please recommend..
