RouterOS v 3.17 and XEN
I’ve tried looking around for this but couldn’t find something similar, so here it goes.
I have v3.13 installed currently handling 7 WiFi connections. All of my cards are Winstron CM9 and the RouterOS is running on a P4 3GHz with 512 RAM from a hard disk. I also run a guest RouterOS via XEN to just handle all of my VPN connections.
Yesterday I’ve tried to upgrade the system to v 3.17… but… It simply doesn’t want to upgrade with 3.17 + XEN + WiFi
At the end I’ve done a clean install including the XEN package (with a 3.17 CD made from the iso file) with out the WiFi cards and all worked well. It booted fine but as soon as I installed on the system at least 1 WiFi card then it all went wrong.
I’ve even tried the disk on 2 other systems (all Intel x86 based) but there is no way to get XEN with wifi together.
The OS doesn’t even boot, it crashes on startup with quite a few errors showing on the screen. You just remove the WiFi cards and all is fine.
Has anyone else experienced something like that, or am I the only unlucky one here?
PS. I’m now at v 3.13 and all is back to normal.
Look here for the same discussion,
http://forum.mikrotik.com/t/upgrade-to-3-14-xen-system-boot-error-3-17-no-luck/24242/7
Sergejs thank you for this. Looks like I didn’t search enough.
Forum admins, please lock this thread.
