RouterOS v3.1 and v2.9.50 connecting problems
Hi everybody,
today I tried to connect 2RBxxx together on 2km range.
One side is RB532A with ROS v2.9.50
Second side is RB333 with v 3.1
these two RB cannot se each other (R52 cards used).
I tried everything (manual TX control, regulatory domain, TX power over the legal norm and so on…)
I cannot see other side (SCAN. ALIGN) from RB532 either from RB333.
This problem was solved after upgrading RB532 from v 2.9.50 to v3.1.
I think this is very bad situation :confused:
After upgrading RB532 with v3.1 I see that my RB532 lost its system performance.
The winbox controlling is slower and the winbox disconnects sometimes from RB.
we have had the same issue with 3.1 but ONLY on boards with sr9/xr9 radios on them.
trying to make a connection between a ros 3.1 board w/sr9 or xr9 to a ros 2.9.x board w/sr9 or xr9 is next to impossible. we had to downgrade.
this bug with SR9 will be fixed in v3.2
cool!
ETA at all for v3.2?
will it cover the xr9 as well?
