Anbody experienced problems with 532A/R52*2, RoS V3.1 ? Association problems seems to be gone and very stable but all of a sudden there’s no traffic being forwarded on 2.4Ghz. Have 1 Virtual AP on this radio as well.
The other radio is running at 5Ghz and haven’t got this problem.
Seems like disabling/enabling interface get’s everything up and running for a while. Have about 15 clients on it.
Yes i was updating a RB112 that have 3.0 on it to the 3.1 and its now gone so the customer is on the way to pic up a new unit.
So i have to check what gone wrong…this time.
Did the update of firmware but still the same issue. Stops forwarding after a while. All clients stays connected and ARP table shows them all. Maybe a bridge problem. I have sent supout to support.
i uptated rb133c to 3.1 from 2.9.50 and wireless interface disappeared.system resource said that nic is present in system. after reboot card returned to list
I have updated my routerboard 133 from 3.rc13 to 3.1 and all is good works perfect ? so i dont know what is going wrong on your guys ends but im not noticing any problems here… Wireless AP has been up for 2 days so far and no dissconnects or problems atleast on laptop or Cpe unit… I dont know.. But i will watch out for this in other units.. -Jordan
Well downgraded to 2.9.50.. Thinks worked for like 30 mins. Then problem came back. I am sure now that problem has something to do with bridging the AP. I saw that i could ping a client 1! time (one ping went through) then nothing came through after that. I removed the bridge interface and put the gw IP directly on card, then everything worked and have been stable for some time now. Just strange that a problem introduced in 3.1 follows back to 2.9.50 (that has been stable for long time before upgrading).
My best guess is that the R52 firmware has been ‘upgraded’ with the 3.1 packet and stayed there when downgrading. Performace right now is worse than before (users complaining about lack of speed, especially uploads) compared to before i started to upgrade.
Well I have slower sppeds since 3.1, also upgraded to 3.1 & firmware 2.12 and also proiblem remains after downgrade.
Maybe you are onto something with your firmware idea. But then again, you upgraded firmware after problem appeared, after upgrade to 3?
Nope not since i had 3.1 on the Routerboard, think it’s the reassoiciation problem that is solved now. Now this particular board (1 of 35) is running 2.9.50.
Yes, i did the firmware upgrade to 2.12 after having forwarding problems on 3.1 but it didn’t change anything. When i wrote firmware i forgot to say R52 firmware. The radios also have a firmware on them. I know this is undocumented but the behavior of my system tells me that this has to be the issue, especially because this new behavior with slow uploads and bridge forwarding problems persist even after downgrading RouterOS to 2.9.50.
I have a customer well known to MT having exactly the same issues, even after downgrading to 2.9.50.
My problem is that i can’t document it right away because of this particular radio is 50 meters up in the air, and the windy conditions over scandinavia right now makes it impossible to change the card for some time. Just hope MT finds a solution fast.
I had a 532v5 AP stop forwarding traffic today too, and it was the first time I’ve ever seen this happen. Problem happened about 4-5 hours after upgrading it from 2.9.50 to 3.1.
Someone mentioned firmware upgrades for the RB532 and the R52 wireless card. I’ve never upgraded firmware on either before - someone mind pointing me to some documentation or something please.
Actually I have seen the forwarding problem, but its not just been wireless interface - its been any interface and connection tracking has always been off when I have seen it. I just turned it on my AP that had the problem - forgot about that.
I did a downgrade to 3.0 again and the problem with no traffic was still there ,and tha strange thing was when i was going in to the DNS server and did an apply with the old settings the traffic start to move again… And before that i was rebooting the RB532 3 times with no sucess..
So it is somthing strange with the 3.1
//Rickard
