RouterOS v3.30 and v4.1 LCD BUG
Establish first
The empress of the heavy Qi
能不能给个修正的版本 Eail:hlg@xh35.cn
so, what’s wrong?..
It’s a bot. Quite smart :wink:
启用四个网卡的LCD显示,重启后会随机自动禁用几个网卡显示,就是三个或者只有一个启用了,或者有二个启用了
if this is a bot, then i’m quite fascinated…
please make supout.rif before and after the reboot and send them to support@mikrotik.com
p.s. English, please. http://translate.google.com will help you =)
4 NIC enabled LCD display, restart automatically disabled after a few random cards reveals that the three or only one is enabled, or a two-enabled
yes, I’m using Google Translate too )) please contact support@ with supout files
joajoajoasjosjosjos
