RouterOS v4.13 Released
What’s new in 4.13 (2010-Nov-01 14:48):
*) added USB power reset feature;
*) added support for nv2 in wireless-nv2 package;
Torrent:
http://www.mikrotik.com/download/routeros-ALL-4.13.torrent
Regular download:
http://www.mikrotik.com/download.html
( No seeds at the moment )
Hey, thank you for NV2, we have to test it now :laughing:
I’ve tried it on 5.0rc3 and it works great. I hope it’s the same with 4.13.
Hmm should be interesting to see in the lab, I wonder whats actually changed in this version
just completed piecing together files and have a full seed running now.
I thought it is not possible to backport NV2 to 4.x, like uldis told us on this page:
http://forum.mikrotik.com/t/problem-with-mount-point/94/1
But it’s very good you made it, 5.0 is still not stable enough.
I downloaded torrent and I don’t see wireless-nv2 packages among “all_packages”. Is it included just in combined packages? I would be nice to have them separated, I like to update just packages I use.
Yep, Have to say I was completely blindsided by this one as it goes against so much of what MT has said here. NV2 couldnt be back-ported and they don’t add huge new features into existing production versions.
That said it will be interesting how stable nv2 is, for MT to backport it must mean they consider the protocol and features to be stable enough to introduce into their production/stable version.
Does anyone else have the mipsbe combined file? torrents got no seeds
Will this address the issues we have been having with USB GSM Modems?
for future RouterBOARDs, usb power reset allows you to reboot a 3G modem without rebooting the router. This will also help the modems, that can’t load normally upon reboot.
Has anyone else had a chance to check out nv2? Didnt get time today to fire it up in the lab. Looking around the Beta forum a few still have issues with it but havent confirmed if they are using RC3 or not. There are a few (once again) fix’s not in the change log we need
Where is the nv2 package for 4.13?
in the RouterOS big package
It is included in combined packages, but not in “all_packages”.
I’ve downgraded two 5.0rc3 machines with NV2 and 4.13 is working fine up to this moment.
http://www.mikrotik.com/download/share/wireless_nv2_4_13_ppc.npk
http://www.mikrotik.com/download/share/wireless_nv2_4_13_mipsle.npk
http://www.mikrotik.com/download/share/wireless_nv2_4_13_mipsbe.npk
http://www.mikrotik.com/download/share/wireless_nv2_4_13.npk
normounds, will you have idea of when this “pseudobridge” mode are supported whith NV2?
regards!!
for me Ros4.13 and NV2 looks like a disaster.
I’ve upgraded 4 units, two x86 and two rb433ah,
one rb433 after upgrade make so much interference that
rb411 (the same location and ros4,9) drops txrate from 270-300mbps to 52-65mbps,
even if I switch wireless protocol to 802.11 or unspecified, it makes
so great impact!
another tryout was ptp link on two intel atom boards working quite
fine since 6months. after upgrade link rate is lower 112 not 150mbps earlier,
and drastically drops real bandwidth, 20/10mbps btest max udp :confused:
at last one Atom had a R52n card onboard, which after upgrade, loses
clients when a/n mode selected, on pure A with every wireles protocol I’ve tried
could connect max 4 of 9 cpe. i had to change module to new one and, get back
to 4.3 which works for me very good.
Frankly speaking I’m dissapointed. tonight getting back to 4.3.
what’s up?
Have you tried to change the frequency? I had similar problems with 5.0rc3, but after I changed channel on 2.4-only-g AP, everything worked perfectly. After I downgraded this machine to 4.13, everything is still fine.
I agree, 2 versions in almost one week… :confused:
4.13 and NV2 is a disaster for me as well
perhaps i am doing something wrong?
tested with 14 clients to an AP,running NV2 on all of them. i have set the distance to 10 km as the standard 30 is too much for my scenario. also have hwretries set to 10 and adaptive noise immunity set to “client and ap” some clients drop constantly and are getting horrible speeds
Uldis: Why did you write that NV2 is supported only in version 5.x?
