RouterOS v4.3 released
What’s new in 4.3:
*) API - fixed possible crash when running concurrent commands;
*) console - fixed logging commands: ‘warning’, ‘error’ and ‘debug’ were
all using ‘info’ topic;
*) bgp - added routing-table configuration option for instances;
*) bgp - added ‘as-override’ and ‘passive’ configuration options for peers;
*) bgp - added support for Site of Origin extended communities;
*) bgp - fixed some network issues;
*) ospf - fixed problem: when last neighbor on multi-access interface disappeared,
incorrect RouterLSA was generated on designated router;
*) metarouter - allow to specify metarouter’s memory size when importing image;
*) firewall - added ‘routing-table’ matcher;
*) fixed problem - e1000 driver did not work in virtual machines;
http://www.mikrotik.com/download.html
yahooo! =) any docs?
ok, just installed 4.3 on a 433uah and it basically turned two of the interface into “ghost interfaces” (everything looks normal, no traffic going over them)
downgraded back to 4.2 and all good again
Just an FYI
this should be an interesting add on…any wiki or docs anyone ?
actually, it was my feature request :slight_smile: this function should check, whether ip address have a route in selected routing table… but seems like it can only check dst-address… what about src?
I also requested ‘routing-table’ matcher when talking with Sergejs at the USA mum. Thanks to Mikrotik team for adding this feature, it will make my life a lot easier.
Now I just need to implement it!
gbh, it is very important to get more information about your configuration, we need support output file from the router in 4.3, when the problem is present. Please send file to support@mikrotik.com
We have upgraded few RB433UAH, it seems they are working fine.
ok no prob, I’ll re upgrade tonight and generate it for you.
Thank you very much for the cooperation.
my pleasure..you guys do a fantastic job and have a great product, it’s the least I can do. (I am slowly replacing all my routers to MK, now up to 5).
[offtop]bwhaha, USA MUM was at September, 3-4, and my first email to support concerning this feature request was at 3th, September :smiley:[/offtop]
I would think you two are the same person, but I have seen you both in person :slight_smile:
[offtop]
Chupaka, nz_monkey had asked this feature on MikroTik training, which had started just 3 days before.
sent
:blush:
gbh, thank you very much for the support output file. We are working on the problem and solution for it.
Chupaka, Great minds think alike!
I have a good idea of how this new “routing-table” works, and how to implement it, but it would be great if Mikrotik support could put some notes in the wiki describing this new feature, I see there is a note on the BGP wiki page but but it would be good to have a description on the filter page as well as info on how the “routing-table” works inside RouterOS logically…
Again, thanks for the great work Mikrotik.
Is nz_monkey with a strange hair look too? :laughing:
Disaster.
We have a number of RB750s which have upgraded from 3.29 to 4.2 with no problems at all.
Upgrading a 750 from 3.29 to 4.3 bricked the 750 :frowning:
About to try a netinstall.
Tried a reset first and that cured it. Strange.
